0 Members and 250 Guests are viewing this topic.
Yucca
Quote from: -[marco]- on July 16, 2009, 06:37:02 PM
well you first have to make sure that you understand the concept of a virtual ground.(the anti weight)
The Wardenclyffe tower looks like a big capacitive coupling to the charged atmosphere above, is that what gives the thing to push against in order to transmit into the earth?
It would be funny if Kapanadze was splicing into some mili tary groundwave transmitter, and every time he lit his lights the power meter on the transmitter pegged up a little.
HeairBear
Thank you Yucca,
Some other stuff remembered from long ago... The mass(weight) of the primary and secondary being equal for efficiency. I may have read that in a patent, I am not sure. Is that normal practice for TC builders?
An idea for producing scalar waves, by winding the secondary in a non-inductive bifilar fashion like the pic below...
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
bolt
Already covered many times now on this thread why there are TWO earth points for Kapanadze  system. Due to parts limitations and lack of lab stuff / money he is forced to use low frequency that is dead easy to build with really wide frequency tolerance.
The system is an Earth ELF magnetic differential amplifier and pulls free electrons from the ground. Using wave tap at several meters apart the further the better.
With more money and better equipment higher frequency permits more power and one earth - more critical to build.
With perfect lab setup and VHF operation NO earth required use poly phase exciters magnetic coupled produces a TPU.
Whatever method is used the theory is ALL Tesla. Remember SM told you in his notes the TPU is a bit like a radio and everyone should read Tesla to understand how it works?  Hate to bring it up here but Kapanadze is directly related to the TPU it works EXACTLY the same. One is ELF operation the other VHF. All these systems are ambient free electron grabbers and produce COLD electricity.
Yucca
Quote from: HeairBear on July 16, 2009, 08:45:19 PM
Thank you Yucca,
Equalish copper mass is a good plan for TC and for transformers in general I think, unless its a Thane Heins BiToroid transformer,  :), then you want more mass on the secondaries.
Yes that doubled back bifilar would produce scalar waves. I think the bifilar pancake is said to be good too.
Alot of poeple argue that hitting these non inductive type coils with fast rise impulses just causes really high terrahertz RF which can get through really small shield gaps or induce some kind of current in a shield that can then somehow get reradiated at the other side? That´s why I´d like to test for faster than light propogation, it would be cool to see that!
here's a cadaceus (with a metglass bitoroid in the background, my newest project :))
ramset
bolt
Thanks for stopping by
Your input and focus are most appreciated
Please continue to do so
Thanks
Chet
Thanks Grandma
