0 Members and 472 Guests are viewing this topic.
xenomorphlabs
I have constructed an aircoil without any tuning yet, just to get a feel for the build and the whole set-up. A test was made for the signal flow too.
Video :  http://www.youtube.com/watch?v=tWJ30HGqtUc
As of now i can´t store any energy onto a cap behind the FWBR (just for the sake of using an acronym here  ;) ;)  )  After switching the circuit off, no energy is on the cap and while it`s running the meters read a fluctuating voltage.
@Jeanna: I remember you reporting something similar, am i right?
Maybe i have to increase the spark frequency or something, i don´t know.
EDIT: I forgot the HV diodes to actually create the D.C. , was awake too long hehe. Gotta sleep and then fix that ;)
Just for the record, i do not expect this to do wonders at this stage, i just want to share here what i am currently building that´s all :) Very early stage NO TUNING done yet.
Regards,
Xenomorph
jeanna
Quote from: Goat on July 19, 2009, 06:38:07 PM
... a sticky thread related to just acronyms for everyone on the forum.
What say all, should we start a new thread of acronyms?
Regards,
Paul
Great idea.
Please do it!
jeanna
lltfdaniel1
This is why i feel it is worth pursuing.
http://home.netcom.com/~sbyers11/RFenergy_Iono.html
Since i have ordered a useful book about keely i am going to try and get this book to add even more fuel to this.
This is for those who do not click the link.
Dr. Moray first started experimenting with obtaining energy from an antenna in 1909 when work with crystal radios was popular. He was able to light a 16 candle power carbon arc light at half power with an antenna and ground. From antenna experience it is known that a one quarter wavelength horizontal antenna that is one sixth of a wavelength above a reflecting surface reflects its dominant energy in the vertical direction. Assuming a resonance at 5 mega hertz, the wavelength is about 200 ft. Therefore if Dr. Moray had used a 50 ft. horizontal wire about 33 ft. above the conductive water table he would have had all of the requirements to establish resonance with the ionosphere. The ground in the Salt Lake valley is highly salty, and conductive and therefore is a good reflector. Cosmic or atmospheric noise pulses have been seen by this author to establish echoes off of the ionosphere and may have initialized the resonance for Dr. Moray. Dr. Moray continued his dedicated research into the 1940's.
Radio link operators report that,... as they increase their circuit frequency toward the maximum critical frequency, exceedingly strong reception develops.  If the circuit frequency is increased further, the signal penetrates the  ionosphere and communication is lost.
This suggests that maximum energy may be available just below the critical frequency. The reports from ham radio operators about the large increase in signal strength when nearing the critical frequency of the ionosphere, prompted this research of this RF energy process.
The works of Nikola Tesla with energy transmission via antennas may have been close to this process. It appears that his equipment was operating in the kilohertz region. This resonance appears mainly above two megahertz. Below two megahertz the absorption in the D layer normally inhibits reflection for the power levels used in radio.
     Theory predicts the system should operate independently of the grounding wire and ground reflector. If two reflecting antennas were placed in orbit with an adequate portion of the ionosphere between them , a resonant flow should be possible. The following experiment by Dr. Moray shows that the system can operate without a grounding conductor.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
bolt
Radiant energy is NOT radio signals. Therefore these circuits that are gloried amplified crystal sets tuned in to BBC world on short wave with 100ft antenna are nothing to do with radiant energy systems. Sure you might get back 5 volts at 5 milliamps but that is not an RE system.
RE is RF as energized field excites local electrons in air, ground, space and returns magnetic flux.
As Don Smith says "the electricity you pay for is simply a signature copy from the generating plant to move your electrons in your house! They did NOT travel from the power plant." Please remember this because electrons are everywhere already you only have to learn how to move them using volts and when they return to natural place current will flow as an AFTER effect IF required for free. Volts are Joules and they become watts later if a load is applied which allows electrons to flow back to the air or ground or wherever they came from.
Not me speaking or Don Smith Tesla knew this 100 years ago.
aether22
