0 Members and 293 Guests are viewing this topic.
penno64
@all,
I do not have access to HV caps.
I can get plenty of 3kv 103 (.01uf) caps.
What way can these be setup to handle higher voltages like 10 or 20kv.
Thanks in advance
Penno
p.s. Anyone in Australia know of a source for HV caps ?
quarktoo
Quote from: penno64 on February 04, 2011, 07:07:45 AM
@all,
Thanks in advance
Penno
Put them in series and the voltage sums. In parallel the capacity sums.
Australians can't be trusted with anything higher than 3KV because they are too crikey. It would place the entire planet at risk. :)
quarktoo
I'm surprised Larry Tseung and the nutty professor haven't showed up to claim the many different coils are like many tuning forks and this is validation of his leed out theory.
I mean why not. The RF guys took a stab at it and went down in flames. I was going to suggest the chemistry dept. have a go, but Lt Bolo already threw his refrigerator on the pile so we have that covered. Then Dole suggested Hertzian wave compression and of course my usual acceleration rant. Basically the only thing left to do is send in the clowns.
I wonder how things are going over at .99's church of logic sin and Larry. I would check myself but I am afraid of being converted to a religion. Most of the former OU members can now be found wearing pink robes and selling tuning forks at the London airport after Larry programmed them. What's left are making joule thieves with Larry's right hand man Pirate, AKA "the enforcer".  ;D
EDIT
Oops  - I almost forgot. Shout out to the mountain of stupid from the counter intel crowd manned by Grumpy!
Herger
Quote from: exnihiloest on February 04, 2011, 04:09:58 AM
It is not my opinion. It is the state of actual human knowledge, the field theory, based on logic, consistency, observations and experiments.
In this matter, you can oppose neither obscure theories based on verbiage, nor old useless patents claiming extraordinary results that nobody is ever able to reproduce (if such a patent worked, we wouldn't not be here, still searching for FE).
To be credible in this matter, you can only show facts which would contradict the common knowledge.
So instead of listening to magic sentences as "If you use a steady magnetic field around the pulsed coil, then you do not need resonance, and you can use any frequency.  Adjust for best effects", you should do it yourself. I guess the author is not convinced himself, so he let waste the time of others rather than his.
This must be quarktoo in disguise.  Negative talk and no work.
When at resonance, the current and voltage are in-phase.  By using a separate steady magnetic field, the voltage is always in-phase.
The fact that the coil around the cap has to be vertical is very interesting.  Perhaps you missed that.  Looking at the video, I only see one wire on the cap, so maybe this information is incorrect.
LtBolo
Quote from: quarktoo on February 04, 2011, 01:14:19 AM
His theory uses a compression which is the opposite of both voltage and subsequent electron flow. These are vacuum energies and any absorption or transfer of energy would only lead to entropy or losses.
Say what? Entropy and losses? I think you left out the critical piece...the expansion and absorption that leads to gain.
I am really not a big theory buff, I just insist on having some idea of where the gain is likely to be occurring before rushing off to the lab. I suspect that many would get further than they do it they would start with an idea of where the gain should be coming from. I think there is a real problem of missing the gain if you don't know where you expect it to begin with.
