0 Members and 483 Guests are viewing this topic.
PARAV
Quote from: xenomorphlabs on July 17, 2009, 09:37:57 AM
The Components (as marked in the previous pics):
H+I: Inverter 12 V DC to 120 V AC
G  : Small Neon transformer 120 V AC to 4kv to 6kv AC
D:  2 x 4kv capacitors ( to tune the oscillation)
F: Hi Voltage Cap-Bank (50kv  to 100 kv total)
C might be just for stability as a whole, but he is tapping the secondary in the middle for the shunt!
So he ends up with  2 coils on the secondary side which alters the discussion about the position relative to the Bloch wall
The other side is visible in this image:
Hi xenomorph:
Great photos - Does any one know what the brown tubular thing with the  two coils on it are on the out put part of this unit?
Also at the output of the neon transformer where the two .1uf/4000v caps are soldered -there appears to be 3 leads coming out  from each end of the two caps -indicating a third cap or something hooked up there in behind those two caps.
I've been trying to draw a schematic - by visually tracing the wires and such  and getting stymied at the moment.
Do you have any more photo's of the unit at other angles?
Thanks for the great shots - If you can add any more info-It would be greatly appreciated.- PR
PARAV
All
The previous post was in reference to xenomorphlab's photo's on Page 44 thread no. 438 on this subject
Parav
xenomorphlabs
Quote from: PARAV on July 24, 2009, 12:54:22 PM
Hi xenomorph:
That is the output transformer AC socket with the two primary coils (center-tap-divided) wound on top of it. The secondary must be under them i guess.
There is only the 2 leads coming from the NST connecting to the rectifying diodes which then connect to the caps. Where do you see a 3rd lead?
Except for the spark gap going back to the NST?
By the way, i really think someone should open a new thread related to Don Smith replications, since this thread is after all about Kapanadze´s devices. That way the development efforts of you guys can be more focussed to that thread
dutchy1966
It's the feedback for the self powering.
See here, it says it with the picture....
http://www.28an.com/altenergypro/device03-2.htm
regards
Dutchy
PARAV
Quote from: xenomorphlabs on July 24, 2009, 01:06:33 PM
Thanks for getting back
Yes I see the two leads coming from the NST - but if you look closley at each end of those 2  parallel caps you will see 3 leads coming out of each side then joined together and going down to the terminal block. Anyway, we'll figure it out sooner or later and yes I agree that there should be a separate thread on the Don Smith
inventions even though some are saying that it is the same principle as Kapanadze's.
Yucca thank you as well,--but where or how does one get or build one of those types of coils-we need more info.
Thanks again guys--Parav
