0 Members and 1011 Guests are viewing this topic.
Pirate88179
Yucca:
Fantastic job man!!!!!!!!!!!!!!!!!!  5 Stars on your video and your device.  those numbers are incredible and that spark......man that thing is HUGE.  Very well done sir.
Yucca
Quote from: hartiberlin on July 29, 2009, 06:02:53 PM
@Yucca,
well done.
Now you need the right 50 or 60 Hz transformer resonance frequency LC circuit
to pulse this via your HV circuit.
OK, I will experiment with 50Hz resonance or a higher harmonic of it when I start making the LC aircoil arrangement. First of all though I will try some arbitrary frequency and try and work out efficiency of the aircoils as a general transformer.
Quote from: Pirate88179 on July 30, 2009, 08:00:13 PM
Yucca:
Thanks bill, I'm pleased with it, got myself a reliable HV supply now for very little cost. I can also dial it right down to 4V supply for like 5kV output. If you see a trashed TV, grab it, some great parts in there!
@all
I have ordered all parts to start experiments: heavy guage mag wire, HV diodes, various HV caps, HV resistors. I will begin winding when the wire arrives in a few days, I will have to wait longer for the HV components from china. I plan to make a HV potential divider so I can monitor cap charge on my scope without danger, this will allow for fairly accurate power measurements both in and out.
I am wondering about the low turn secondary pumping up the output caps via the diodes, will this output coil resonate at a fixed freq? Maybe not, I think the resonance might change depending on the charge in the storage caps? Anybody know more about this? DO I even need to worry about resonance on the output stage?
xenomorphlabs
Quote from: Yucca on July 31, 2009, 11:09:54 AM
If you rectify the output of the secondary coil, there wont be an oscillation in the secondary  circuit. That relates to a FWBR diode arrangement.
Yucca
Quote from: xenomorphlabs on July 31, 2009, 11:41:38 AM
OK, I thought maybe that. So we build a secondary stage that can collect and store the energy as fast as possible. The tuning is only in the primary, if indeed we do have to tune to some magic frequency.
Maybe some residual oscillation will remain, that which is to low for the diodes to pass, and occurs from the coils parasitic capacitance, it would be very high freq, I will disregard secondary tuning to start with.
dutchy1966
Hi Yucca,
Great job you are doing there!
If we look at kapnadze's patent it seems to me that you now have build the part 1/2/3/4/5. Basically you have got the high voltage sparkgap running nicely.
As far as I understand kapandze and Don Smith the next stage should be connecting the low turn primary (part 6 in the patent) of a tesla transformer. The back and forward rushes through the sparkgap will be amplified by the Tesla transformer. This is where the magic happens. Then the output of the tesla transformer's secondary needs rectifying by a high voltage FWBR. Only after that comes the Inverter circuit and (step down) output transformer.
I'm not really sure if that is what you are trying to do...Can you explain what you're trying to do next?
Keep up the great work, it's appreciated!
regards,
Dutchy
