0 Members and 502 Guests are viewing this topic.
Bruce_TPU
Quote from: TEKTRON on May 31, 2011, 10:41:20 PM
Not yet, but I was thinking it would be cheap to do. Maybe wrap some coils around it and see what happens ? ;D
If it works as advertised (they never do) then coils would not be needed.  But you should certainly (safely!) experiment with it and see!
That paper did indeed give me two (brilliant!) ideas...lol  1.)  Use the Steel tube as the positive plate (collector!)  2.)  Use the CT to earth ground, giving a steady supply of negative electrons!!  (I think this will help!)
The pipe tube will ONLY give amperage, so I would wind the pipe tube with many winds, rectify it and connect with the output of the positive plate (steel tube).  Now THAT would be interesting!   ;)
Cheers,
Bruce
wings
Quote from: Bruce_TPU on May 31, 2011, 11:26:01 PM
Cheers,
Bruce
suggestion for test
During test take in account the multipactor effect of the surface using different materials.
The multipactor effect provide the emission of secondary electrons from the surface using two different materials you have two different electrons emission and then different potential volage.
or
use the same material with different surface area and you have same effect.
other effect:
-connection to ground = free electrons or ions
-magnetism of iron bar = improve rotational effect of emission?
http://en.wikipedia.org/wiki/Multipactor_effect
Shokac
Quote from: electricme on May 31, 2011, 08:47:54 PM
@ Chokac,
This is a nice photo of the Vacuum tube and it,s acompanying components, may I ask you for the http address, I was wondering if there was any other info about it avaliable, maybe text etc?
jim
http://www.electronicsonlinestores.com/classic-vacuum-tube-film-dvd-1943-electronics-history-of-electron-cathode-vacuum-tubes-and-early-transistor-valve-technology.html
