0 Members and 476 Guests are viewing this topic.
stivep
Quote from: dole on June 17, 2011, 10:51:39 AM
I would say standing wave, but there is more there and as more I search and research I’m getting just more and more confused.
We have evidence of something but I still do not see the source, the principle, the rule.
d.
Dear Dole
Standing wave is similar to BEMF  in nature.
VSWR stands  (for return component of power) Voltage of Standing Wave Ratio.
SWR  1:1 means that all energy is send  out.
the terms above are in use for Radio Frequency power transmission lines and/or antennas.
http://micro.magnet.fsu.edu/primer/java/polarizedlight/emwave/electromagneticwavefigure1.jpg
The electric field in an electromagnetic wave vibrates with its vectorial force growing stronger and then weaker, pointing in one direction, and then in the other direction, alternating in a sinusoidal pattern (Figure 1). At the same frequency, the magnetic field oscillates perpendicular to the electric field. The electric and magnetic vectors, reflecting the amplitude and the vibration directions of the two waves, are oriented perpendicular to each other and to the direction of wave propagation
electromagnetic wave CAN NOT travel  through a conductor but  along to conductor.
direction of current is determined by current flow vector at the conductor
So if magnetic flux is horizontal  than electric field is vertical (at 90 degrees  to magnetic flux) vector
At this point( if we have vertically placed capacitor than electric field will be parallel to the metal tube of this capacitor.( magnetic will cut and penetrate  across capacitor)
http://micro.magnet.fsu.edu/primer/java/polarizedlight/emwave/index.html
I have made interesting experiment and this experiment was repeated by my friend John from scientific group.
electrolytic capacitor (DC 8500  micro-farad) that  is placed in its own metal enclosure represents with out any modification RF Chamber
and/or = Faraday cage
The exemption is that two  leads + and - are on the top and that part is open to RF.
So say metal cup is placed and is closing the enclosure to make Faraday cage.
As the capacitor is 10" long you will wind as many as you can winds of the wire. on its surface.
Than you will connect two ends  of this winding to generator say 0 to 20MHz and say 1V sinus wave.
Than your 50 Ohm  coaxial cable from oscilloscope is connected to + and - of capacitor  such way that cable by itself go through small opening in the cup covering leads,insuring proper shielding .
When  the cup is inserted on the capacitor your  eyes will see perfectly
sealed and strapped metal cylinder.
The investigation conformed that when  resonance frequency was achieved ( few different spots... look at the highest one)
The voltage on the capacitor was at (my case) 4 times bigger than delivered one.
The voltage on the capacitor was at (John's case) 2 times bigger than delivered one.
The conclusion is that magnetic filed can penetrate Faraday cage but electric component can not!!That my be due to 90 degrees angle of electric field.
and inability  to penetrate.
Notice that amplitude of both components is the same.
If Yes Than
only 50% of total (summary of both fields) is utilized to create impact on capacitor.
So again:  the magnetic flux of EMF is responsible for voltage created at capacitor.
WHEN REVERSED (GENERATOR  CONNECTED TO CAPACITOR AND COIL TO OSCILLOSCOPE) THE EFFECT REMAINS THE SAME.
If we picture that ratio between winding and foil in capacitor is 10 :1
than voltage induced should be 10 time less than delivered and when reversed 10 times larger.
But because of resonance and not fully examined impedance the amplification factor with regards to ratio may vary.
Question How in the world it is possible that in both situations
We are dealing with greater voltage at output.
Yes someone  may notice that power =voltage times current.
So what.
Show me one transformer at ratio 10:1 that interchangeably will show 4 times more output than input disregards the fact what you have used  for output and/or input knowing that generated voltage is always 1V.
Can You?
Wesley
ps:
1.Square wave in  scenario above is even more fascinating.
Shokac  I'm still waiting for response  To
Kilovat. Something  wrong is going on..I'm so close and can not touch it as of yet. If it was - what was promised it should be over already.
2. can someone tell me how to properly post pictures on this forum?
bolt
Quote from: Shokac on June 17, 2011, 03:51:47 PM
Do you have a proof for your statment?
Yes i have a sworn statement from SR193  that backs me up. All my own research tells me it valid. No i don't have a working one yet that takes a lot of R & D cash i don't have.
Save these notes for when someone else makes a full disclosure then you can check back just like RomeroUK's  muller i posted many times prior to his disclosure that looping these things is very real, not so difficult and gave many examples of how to do it only to be sniggered and laughed at the last few years as "IMPOSSIBLE" or "i eat my hat if a motor generator can be looped"  I now given basic principle of operation as electrostatic capacitor can be formed from a copper pipe,  HV source,  aluminium foil, ferrite rings, bifilar coils, modulator circuit creates nuclear transformation of ferrite to  isotope converts to incredible high VARS.  For 5kw system will be around 50KVAR of modulated magnetic flux.
I looked over most of the circuits in this thread and in my opinion 90% are completely wrong, 10% are close and 1% might work if constructed properly.
The 100KW system may look like Tesla coils but they are NOT!
poynt99
Quote from: bolt on June 17, 2011, 10:03:47 PM
Did SR193 have a lot of cash?
.99
Magluvin
Quote from: poynt99 on June 17, 2011, 11:16:24 PM
.99
Cmon,  thats not fair point.  Lots of cash to some people could be just $100 to you. These days people are loosing their homes, let alone put food on the table for their families.
Some reasons people have are not always excuses. ;]
Mags
Shokac
I tried many experiments and I burned a lot of equipment, purchased new, and started again.
The only thing I have in all this he concluded that the Gap and across the spark coils can get a high current at high frequencies. And that very high currents. (approximately 5 to 20 A).
Spark gap I put in a F cage and measured the current at zavojinici. This energy has no voltage, or very small
Now we are working to raise the frequency of 220V power and put it all together in phase.
But I am convinced that the solution is much easier
