0 Members and 279 Guests are viewing this topic.
forest
Noise could be from spark gap. I mean not sound but RF noise.
bolt
Quote from: xenomorphlabs on July 16, 2011, 11:29:45 AM
@Bolt
I remember you were pointing out an unusual noise in the Thrapps Motor when the ZPE extraction starts.
There is certainly a powerful process going on in the core of Kapanadze (5kW and also 100KW device) , because
you can hear an extremely loud noise which i had just attributed to magnetostriction (just like in big AC transformer stations).
Comparison Kapanadze (at 1m10s) : http://www.youtube.com/watch?v=uxQ99R4gOWY&playnext=1&list=PL30812BFE4627BB4E
Thrapps (at 0m57s) : http://www.youtube.com/watch?v=LgEsSOphlp8&feature=channel_video_title
Thrapps Motor makes a very distinctive sound as it hits resonance. Thrapp explains why he must tune to a certain speed as the system is matched into the lamp bank load.  The sound you hear at running speed is more like a GROWL as the system is completely  reactive into high VARS and tuned by the cap bank on the generator.  The operation in high VARS creates a powerful magnetic flux on the generator which vibrates the coils and magnets and this causes the loud sound while at the same time most of the BEMF is NULL and so little load on the drive motor. My guess is this system has a COP around 5 which is plenty enough to loop and run the load. So 1000w of lamps is pulling around 300w off the motor =  1500w gross -loop and conversion losses. Listen to the old original mullers they are very loud when they hit full resonance as VARS. Sorry this is not the muller thread but many things are highly related to each other.
100kw kapanadze system is not JUST a Tesla transformer as you would think its a large capacitor being pumped with displacement currents. You can see the primary tesla coil but this gives a HV pre charge into the mega large capacitor cylinder > 100kv.   On the base of the cap is a secondary very thick wire coil in base box to collect displacement currents are reacting to massive pumping magnetic flux drawing ZPE then to drop to 480v while the device is actually operating in high VARS. Most of the noise is not the spark gaps its will be the coils shaking like hell responding to very high magnetic flux.
  In other words its RLC pumped out of phase. Of course the system is 3 phase for 3 devices. The displacement currents from DIY cap is going to be in the order 100 times less efficient than using ferrite or iron as ZPE proxy to fill the dielectric layer. The COP of this system i think was around 10. Most of the loss will be due to phase angle shifting under load out of pure VARS allows current to pass the spark gap from the primary as perfect setup should keep max spark voltage versus max current on cap then as cap hit max voltage spark reaches max current at 90 degree shifted NODES becomes skewed and loads the primary Tesla but due to the huge amount of power involved i doubt anyone will complain gaining 10 times energy out than in.
Here is an electrical EQUIVALENT.  Please understand its not the actual circuit as the load coil inductor is not directly connected to the cap but wrapped around the  base of it to collect the displacement current induced magnetic flux as the dielectric is charged using out of phase high VARS impulse spark gap.
stivep
Quote from: dllabarre on July 15, 2011, 09:01:47 AM
FINAL?   >:(
Where's the schematic?
Where's the parts list?
Where's your working model?
DonL
Thank you  my friend for your response
for link:
http://www.umbrellatech.lv/downloads/files/Design%20Of%20Device%20-%20final.pdf
I have material that is not complicated but gives you what you need  from scientific point of view in regards to sandwich ferrite rings with dielectric.
http://www.ece.unm.edu/summa/notes/Measure/0046.pdf
Wesley
Ps: I did not draw my conclusion as of yet ..When I have little time.
But it is what "ambrela" is relating too
Wesley
slapper
Quote from: stivep on July 16, 2011, 10:04:46 PM
[snip]
[/snip]
thank you for the link to this document.
scrolled to page 3 and there it is.
alternating high and low permeable cores.
take care.
nap
we are not alone :)
slapper
we are not alone :)
