0 Members and 121 Guests are viewing this topic.
minde4000
So primary is a hi Q driver wich kind of resonates with time decaying Q pulse trains and at relatively high frequency (Mhz range as you said).  At what harmonics primary couples with secondary to make secondary resonate?
Also here are two different resonator drawings. Are they different? They both serial and same or different? :)
Thank You
P.S. My new HV ps just died. My transistor was only 60-80V. And I think on receiver leg with scope I saw large transients but thats was before I got it working so I have to recheck that when I will get more transistors. It was getting hot too.
forest
Don Smith is using something like that attached in one of devices. Spark gap is really spark gap arrester.Cap is DC HV non electrolytic probably . Does somebody knows how that works ?
Yucca
Quote from: minde4000 on September 15, 2009, 11:59:55 PM
Thank You
The top schematic is what Smith seems to use, just like a regular T coil. It only works if the HV supply is DC offset (all above zero). Most all flybacks have integrated stack diode on the output so it is just right for this and you would end up building what forest has drawn above.
Your bottom schematic would also work with a rectified supply, but probably best to start with top config.
edit: try and get a tranny thats rated for high max reverse vge.
To stop heating you can try softening up the base signal, if you slow the base rise time using a small RC network (R parallel to C) between base and ground then junction heating will be greatly reduced. Use a small electrolytic cap and maybe put a 10k variable R across it for tweaking.
But it's best to get a tranny thats designed for powerful inductive load switching at fairly high speed, I find 13005 to be the best, I can wind input PSU to about 25V in my setup before 13005 gets zapped by the inductive kickback from the primary.
edit2:
Another way to soften base drive is to just change your existing resistor divider network, inrease both resistor values, could try doubling each resistance to start with, keep the same ratio.
minde4000
I ran into 13006's this morning at surplus store. Fired up smoothly ran for 15 min raw with no issues except that tranz gets pretty worm to the touch (will tune this out later). Now its running 12.3DC @ .5amp and even on half dead 9VDC battery MMT shows 4DC @ 20ma trows 1/8 visible sustained arc. But thats an inductive load to dc source so MMT measurements are not valid. Either way seems to be very cheap and efficient HV power source.
  These multiple stage transmiter/receiver resonant amplifiers look very real (and very tempting)  ;D
I wish I could afford at least one of these 1nF 10k variable vacuum caps on ebay for $240+.... Awesome quality caps for such hi Q amplifier. Math behind multi stage coupling resonant systems still behind my reach. Anyone knows what happened with Kapanadze guy and his inventions? Latest videos are kind of old already.
Thank you.
Minde
baroutologos
Hello there!
I see finally we moved from ol' mechanical rotating systems to RF of resonance! hehe :)
I have studied a little bit if Tesla patents, since Kapanadze and Don Smith Technologies are Tesla originated. All talk about frequency and voltage are key factors to "mutliplication factor".
ok guys, sorry for repetition here. I am willing at joining experimenting. It seems that i have more or less to make a mini Tesla coil and conduct some HF HV experiements i guess.to get a feel of this technology.
By the way, i am quite impressed that this Tesla technology is heavily depended on grounding! Some videos i watched about some Georgian that had a FE device, had a radiator as ground whereas others a water pipe.
Grounding should be of importance in HF HV resonance circuits i guess.
Regards,
Baroutologos
