0 Members and 77 Guests are viewing this topic.
TEKTRON
Quote from: Hope on October 29, 2011, 02:27:27 AM
Found lease costly radiation detectors at Goldmine Electronics.
Comment if you can read this????
got a link?
Jury1
Quote….Concerning your experiment, i guess i should look into it more, but it
more or less reminds me of this old series (2008) of experiments (Simple transistor/coil oscillator with inductance and interwinding capacitance ) :
http://www.youtube.com/watch?v=d8pUR9R9Sd4&feature=channel_video_title
and originally from here:
http://www.youtube.com/watch?v=Lx5En4Yv9iY....
@xenomorphlabs
I agree with you. Is the capacitive effect of the primary and secondary coils HV transformer.
IMHO important role to play the Miller effect and piezoelectric effect in the base of the transistor. This is the engine of the process.
HV transformer - capacitive resonator ...
Electric circuit of the device is disconnected. In this circuit there is no electric current. If you use an analog ammeter, then you it will not see anything ...
Welcome to the "open system"!
Here does not work Ohm's law. This law is working in closed circuit ...
Modern equipment measures the current process inside the wire, but it is useless for measuring the electrostatic induction ... Why?
Because the static potential is perpendicular of the electric field of power supply ...
How does "open system"? The answers I find in the patents of Nikola Tesla ...
He was “The Last of the Mohitsans”,  who were engaged in "open systems" ..
When I realized this, I began to get interesting experiments ... I discovered a Terra Incognita.
An important quality of "open systems" is the ability to interact with the environment through capacitive coupling
Quote… I am also very interested in your solarcell radiation measuring experiment. Can you explain it little bit?....
I think that the radiation source is a plasma. Plasma is the result of skin effect on the surface spiral lamp.
[IMHO] I think,  that the electron out of atom exist in form of quantum wave...
At the lamp is fed the sine 150 kHz.
In the  lamp   power circuit I connected the  starter from a neon lamp.
http://www.elektro-planet.com/shop/catalog/images/7905-z002.jpg
After heating the contact,  the circuit is broken.
We have an electrostatic impulse.
The potential electrostatic impulse   is much higher,  than the potential in the closed lamp circuit.
So after closing the circuit there is "braking radiation" or "deceleration radiation".
The p-n transition of the solar panel to absorbs this radiation.
[/IMHO]
energia9
i find it tricky to replicate device....    i find that its not going to be easy, if i would have made such device, i would took photographs of every corner of the device, showing all in clear, also explaining why where and how we need correct capacitance adjustment for setting resonance,  and the ferrite bit. i cant even imagine how they have it,  how do we adjust it etc.  i did not quite understand how are we actually getting (cold) electricity that doesnt burn through paper...   i know you have shared plenty of info,  but i feel, that when a person masters this knoweledge, it will be extremely difficult for the other person to replicate because of the way we understand things completely different.
masters of the device :  Aidas and Arunas,  we need to find a way to implant the ***exact*** knoweledge and ***logic pattern*** in our heads to accomplish the magic
btw , im sure some of you have seen this before, and i wonder if the idea has something to do with this:
and this could be the reason why we see wries going through tariels device alll the time. he might not use ferrite, but plain copper!
To shake atoms so they render the energy they contain, you must send via a high frequency oscillator (in the order of 173 kHz) a wave that is in resonance with the vibration of the copper electrodes. This is via an oscillating magnetic field thanks to the coil winding that is connected to the oscillator and that covers the copper. One part of the feed current is used to polarize the metal that restitutes (gives back) up to 30 times the energy consumed by the oscillator.
http://www.rexresearch.com/meyernmr/meyer.htm
this person claimed he generated 40 watts from 1 watts input by resonating a copper rod,    i will try to send hv oscillations to the copper tube and adjust, see what happens.
forest
energia9
According to Meyer-Mace schematic that would imply ferrite flyback core connected electrically to the output ???
xenomorphlabs
Quote from: Jury1 on October 29, 2011, 04:10:32 AM
@xenomorphlabs
An important quality of "open systems" is the ability to interact with the environment through capacitive couplingI think that the radiation source is a plasma. Plasma is the result of skin effect on the surface spiral lamp.
[/IMHO]
May i suggest to you since you want to discuss/present you experiments that you
1) Briefly describe, for each experiment, what you intend to show
2) Name the components/elements used
3) Provide a schematic
4) State what is measured and where and interpret the measurements
Scientific experiments are always extremely documented for a reason, so
anybody could replicate them
It is very hard to understand an experiment from a youtube video with not a single word of description. It might be all obvious to you, but not to people who see it for the first time.
You were mentioning that "Electric circuit of the device is disconnected".
I don't understand this statement, the battery is connected with both wires ?!
@Energia9: I agree with you, unfortunately the schematic provided is insufficient and should be unambiguous. Common features of a schematic were omitted like supply voltages and component specifications.
It's a standard problem, when a person is too involved into his/her own experiment, then it all seems so easy and clear and that's probably the reason
why some schematics tend to be without much detail.
But it is their choice, they chose to present it like that. Nothing else to do than respect that.
Concerning the Meyer experiment you posted.
I personally think that it is a bit closer to what TK is doing, because exactly of what you are saying, that the copper wire  goes through the coil former of his devices. In the green box it's the earth cable, in the new device it is possible that the output cable to the lamps runs all the way through.
In the Aquarium device the core is a BRASS ROD !!! (NOT iron or ferrite)
