0 Members and 73 Guests are viewing this topic.
T-1000
Quote from: romerouk on November 04, 2011, 01:30:45 PM
This one I got today and it works excellent. It can be used as frequency meter too. http://www.ebay.co.uk/itm/2MHz-DDS-Function-Signal-Generator-Source-Module-Wave-/250895654856?pt=LH_DefaultDomain_0&hash=item3a6a8bdfc8
http://www.ebay.co.uk/itm/5MHz-DDS-Function-Signal-Generator-Source-Module-Wave-/200608274325?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item2eb52f5795
Seems they're even better ones :) Ordered 2 of them for dual frequency generation and low voltage circuits. Still need to play around with mini-toroids and see if I get same effects we have on TV yoke ferrite.
John M
I design radio scanning systems using the AD9851. The generators posted using an on board LCD looks good.
2 or the 5mhz might not be much, but with the on board controls and display, not bad.
John
T-1000
We use multiple wave forms. Sinusoidal generators are limited to single wave format. Also we do not want to use radio frequencies, so we are doing even on less than 1mhz. Ferrite resonance is less than 5mhz. And here it define what we need to get if no tools on table :)
John M
I run the AD9851 up to 60mhz output with no problems. Of course like T-1000 said we only need frequencies below 1mhz.
John
bolt
a CD4046B  Phase Locked Loop will run up to 1.4 Mhz and cost about $1.20 that is my signal generator:) Can use prescaler to lock sync to 50Hz or thereabouts is NOT critical. Only the phase between the two signals are important once the critical sub harmonic NMR frequency around 380Khz has been found. A  square or pulse wave will suffice as we need to hit higher harmonics.
