0 Members and 220 Guests are viewing this topic.
dllabarre
Quote from: cosmoLV on November 07, 2011, 06:23:28 PM
How i understand ans see stevep and others push peoples far away back from real principle of the device! Wry clever and you are still believe....
Why you not take for real what Tariel say? why nobody see at linde's device which Tariel shows at end of green box video? why nobody look at electricity as water and gas?
where are engineering - Kid Garden!!! Return to earth and think with your own head...!!!_______
Please tell us what Tariel said....
DonL
aether22
Quote from: energia9 on November 07, 2011, 08:02:17 AM
i have experimented, things are happening the exact way aidas, arunas, wesley say, no theories will make your device work!  DO IT and you will know!!!
everything has to be adjusted piece by piece, you will not suceed with a fixed thing....
trust it, the phenomenon is not explained in conventional science, and media will still try to supress it although it can be reached by anyone this time.
All physics books needs either adding more info or completely rewriting... :o
energia9, are you saying that you have achieved obvious OU, lighting of a high wattage bulb with only a few watts input?
OR are you saying that the tuning is going at T-1000 et al said?
I read it as the latter, but if you are actually getting OU can you please make a video or at minimum a circuit diagram and parts list.
Please share!
verpies
Quote from: grizli on November 07, 2011, 05:52:30 PM
where is ferroresonance in whole story ?
What type of ferroresonance do you suspect?
1) fundamental mode,
2) subharmonic mode,
3) quasi-periodic mode,
4) chaotic mode.
Once again:
At what frequency do you think the ferroresonance occurs?
To which coil is this frequency supplied in order to evoke ferroresonance?
P.S.
For clarity's sake, let's use these phrases when we write about the two different kinds of coils:
A) "Transverse Coil" to denote the 1turn coil made out of Copper Plates (or Braid)
B) "Longitudinal Coils" to denote the conventional coils (15turn primary, 50turn primary, and 150turn secondary output coil)
It's easy to remember because Conventional Longitudinal Coils magnetize the core along its circumference and the unconventional Transverse Coil magnetizes the core transversely (parallel to the major symmetry axis of the core).
grizli
Quote from: verpies on November 07, 2011, 06:35:38 PM
4) chaotic mode.
Once again:
P.S.
It does not matter how we call it :
but effect is :
you put noise to 50 turn coil and read peak at 90 degrre coil with spectrum anayser,
that peak is not natural resonance of 90 degree coil , because peak is much sharper and , if you look spectral analysis you see another rising at much higher frequency
stivep
I'm Disappointed
What is the total lose?
1 ferrite core from old TV the best 90 degrees deflection yoke.
we did not try any other one so far. $20
1 set of wires... used one... no cost.
2 capacitors variable.. with large gap  up to $100 together.. take out every  second plate to enlarge gaps.You will need them for other experiments anyhow
2 generators you can make them $10 each or buy them ready to use. You will need them for other experiments anyhow.
remember  advice of members about generators.
1 flyback from old TV  no diodes in it molded to plastic.!!
ANY OTHER  TK EXPERIMENTS WILL UTILIZE ALL OF THAT STAFF.
SO WHAT IS THE LOSE?
N O N E !!!!!!!!!!
And cosmoLV can you tell us what TK said?
there are  two concepts to try both successful.One is TK based or Smith if you wish...  They can always switch to second one...
So it there is any doubts in your mind Sir how can you explain them?
But do not answer with question for our questions...
FACTS Please !!!!!!!!
Wesley
oscilloscope? $100 used one.
spectrum analyzer $450 old HP or get computer driven.
You  need them for any experiments if you wish.. But when team help each other new methods will be developed.
________
