0 Members and 66 Guests are viewing this topic.
John M
Was the question ever answered as to why you must sync a 50hz to a 387hz pulse. All I see is the 387hz riding on the 50hz wave. Now if the harmonic of the 50hz wave equaled the 387hz wave then it might make sense to sync it.
John
Mannix
I wonder if a 3 to 1 ratio for wire lengths/or mass will be important ?
15 50 150 pretty close uh?
If so, wind 52 turn and un wind/tune/cut  for desired freq,then completely unwind and measure ..or weigh.
Then use that mass as reference for input 50+/- hz and output.
Remember Otto? he found  that 1 cm of wire lenght would make bright light or very dimm light.
I am away from my bench for a few days,frustrating , too much thinking!
@stivep you are being "assesed" ..get info out, the target will be big as it already is becomming.
Very nice people  arent they?
aether22
Quote from: John M on November 08, 2011, 04:21:06 PM
John
Yes, it would make it 1/7640 of an impulse larger or smaller.
Of course it might still be required for some reason so I am going to checkout the manual for the FG used to see if it does have a trigger as some are saying it does and some saying it doesn't.
I shouldn't have just assumed those saying it didn't were right.
Update: I have looked closely at the Velleman PCGU1000 and it has 2 waveform outputs, I don't know if these can output 2 different frequencies, I hope so as if I go with it I'd only need one.
And it has a TTL-level synchronization output, note that is an output not an input.
Therefore unless someone who has one can give a procedure for doing something it isn't meant to do, I can't see any way this function generator can provide a synced output unless it does so on a software level, but T-1000 said it involved a pickup coil.
Therefore I am suggesting that phase be ignored until T-1000 tells us how to do what currently seems impossible and senseless.
It can only serve as a smoke screen.
cosmoLV
Quote from: stivep on November 08, 2011, 09:26:47 AM
for period of last 4 days:
-strange approaches relay strange.. ( not to tell right now mostly  offers even "provoking" one of any kind of  "services" of favors.) Never happened before.
-offers to  free cleaning my  house at no charge.( never happened before)And  Lady persistence   to convince me that I should do it and based on special offer I might  not be charged for any cleaning for a certain period of time as they chose only one customer per  town,  per year.she was presenting real professionalism. Beautiful communication skills and communication at the level of good university  with many years of political and negotiating  experience.
She was too good for the secretary of "cleaning company.."
- competitive energy company offering door services without my  approval.Demanding that they need to check  the property (without proper authorization)  This one was nasty..
I ask him to leave my property immediate and he was standing still as he was thinking what to do next.  He face me with the "authorization letter" and demand from stated to be Con Edison  (that after examining was just a energy company  flyer.)
All of the cases look like "professional  job"
But did not look like "agency" professional job.
"agency" does not have problem to locate me or approach me.
Saudi log to my you tube 8 times.. never happened before  (usually 1 hit the most.) Strong interest from  "lady" "Venezuela"
There is more that  I did not tell as of yet.
I'm very serious in my comment here.
yes, but nothing strange ;) you need to know, when you get free energy, they cover all - you need to be smart doing this.
i told this several times, but nobody listen me, everybody believe in miracle that free energy give a freedom
(nothing like that) this technology need to be implemented in smart way - they are not idiots ;)
i have lot of friends in government and police,
i have inuf information about they tactics and control process and they have wide range of variations and strategy.
Pleas return to earth if you want to win, don't do stupid and fast things, think twice before do conclusions and take actions.
Keep your chakras opened :)
verpies
Quote from: Osiakosia on November 08, 2011, 01:58:12 PM
Good day for all ,
I have a luck to find whole TV unit "Rubin" .
Here is few photos . When measurement equipment
will arrive in my workhouse I will try to make replika
of this OU device . If you need measurement of the ferite
please let me to know .
Congratulations.  This is exactly the same ferrite that Wesley and Aidas were using.
1) Please measure the dimensions of the complete ferrite cone (with two halves joined together).
  a) Total Height
  b) Height of the narrower (cylindrical) part
  c) Inner diameter of the narrower end
  d) Outer diameter of the narrower end
  e) Inner diameter of the wider end
  f) Outer diameter of the wider end
  g) The mass of the two halves of the ferrite
2) Please measure its DC resistance with an ohmmeter (first scratch the surface with some sharp tool in case there is some varnish or oxidized layer on the ferrite).  Note the distance between the ohmmeter probes.
3) Measure the inductance of a multi-turn coil (the more turns the better) wound over the whole circumference of the ferrite while its two halves are firmly joined together (preferably with the original metal clips).  Please report:
  a) the number of turns
  b) the measured inductance.
4) If you know how, measure the BH curve of the ferrite with its two halves firmly joined together (preferably with the original metal clips).
