0 Members and 256 Guests are viewing this topic.
verpies
Yes, a two transistor H-Bridge is sufficient for digital rectangular waveforms.
The VCO in PLL loop is also more flexible because it allows for phase synchronization between two oscillators.
That might be an important feature if two perpendicular windings need to be driven in quadrature (90deg. out of phase) in order to create a rotating magnetic field in the ferrite.
mikesmullin
closed-caption ability is provided by youtube. i haven't done it before i've seen some videos where i was able to click the CC button to turn it on. i bet its pretty simple and can be configured in the video edit area of youtube. maybe a volunteer could do it
verpies
Quote from: itsu on November 20, 2011, 04:04:15 PM
I will look into those audio/video amplifiers.
Good, look into car audio amplifiers paying special attention that they are bridgeable and stable into as lowest ohm speakers as possible.
For example, the description of the amplifier below states "4 Ohm Stereo Stable" which means that it can drive two 4ohm speakers and if you could bridge its 2 channels then it could drive one 2 Ohm speaker.
$30 Car Amplifier
Note that the amplifier ad above is only an example of the specs and I do not consider it special or worthy of recommendation.
Don't search for the Video Amplifiers or Line Drivers yourself - I'll do that and give you some concrete numbers for the relevant Integrated Circuits.
verpies
Here are some wide bandwidth high frequency linear analog amplifier integrated circuits that are ready to use.
The PA107U is the most powerful HF amplifier IC but it is also the most expensive ($375). The AD8023 is the weakest and less expensive ($11)
Use those if you think that the windings need to be driven by high-power high-frequency non-rectangular analog waveforms. Otherwise two transistor H-Bridge buffer/booster circuits can be used for digital pulses.
Ganzha
Quote from: T-1000 on November 20, 2011, 07:33:15 AM
So we found what is happening. The ferrite core becomes magnet. You need compass to see it. :)
We're working now on constand degauss while preserving all effects.
P.S> The Russian deflection yoke is pure glittering black color. Most other ferrites have more gray color.
Absolutely! We need Compass Tiger has it!
I have to say that in USSR there were a Magic Yoki, Magic inventors and even Magic People. It is pity that West World had destroyed all of that. I am not sure that now we could find "Magic" Yoki and Magic Ferrite from USSR! Sorry!
