Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 271 Guests are viewing this topic.
callanan
Quote from: baroutologos on June 24, 2010, 02:11:51 AM
i was looking at Naudin's equipment for conducting his experiments.
The power meter is Energy Check 3000.
http://www1.conrad-uk.com (search it as Energy check 3000)
The particular device says that it can measure true RMS and distorted wave. By the way, it should operate pluged at mains.
We cannot be sure that if pluged at a variac it makes valid measurments.
Regarding Naudin's efficiencies
Assuming the Energy check 3000 meter says the truth. Apart from the SG optimazation, Naudin uses a Variac for optimal operation of MOT.
IF the MOT at nominal voltage is lossy due to core saturation and not shorted windings(with or without load) at e.g. half of nominal voltage will be probably quite efficient.
The Voltage doubler function of the cap assures that the SG works anyways and to half input voltage. 1.2-0.9mm requires some 2-3 Kv to break. A MOT of nominal 220v input, and 2KV out, at 110volts from variac will reach probably 1KV out. This way, the cap can store phase 1 and during phase 2 to reach 2KV.
Bottom line i think a variac is a must.
Here is another quote from JLN which maybe relevant to your assertions.
"The use of the Variac is required because I have noticed that during the startup, when I turn the Knob, the input power climb up to 900 W and then when the spark begins to start after few second the power drops while the lamps begins to bright, at this moment, the Variac knob need to turn back to lower the input power to about 210 Watts and remains stable."
baroutologos
Hello Callanan,
How you know such details? Maybe you have direct communication with Naudin? If so that would be good since he steers the whole "Kapanagen" or "Naudingen" for me, project.
I have unsuccessfully tried to communicate with him via mail twice. He would not respond at all.
ps: Regarding my "ascertations", i just point out practical problems that i have experience of. ( not with a MOT, but with other smaller transformers)
Its not about theorizing or anything
exnihiloest
Hi all
Here is my setup. It is not an accurate duplication. My goal is to test the elementary phenomena involved and to evaluate methods for measuring the in/out powers.
I put a 0.75 ohm resistance in series with the MOT primary. With two probes connected on each pin and the oscilloscope operating in differential mode, I can monitor the input current. It is rather sinusoidal but there are also very high frequency components that superpose. See photo below. The voltage provided through the variac was around 90v.
Then I wanted to do the same on the output, by connecting the resistance between the earth and the light bulbs, in order to see the output current with the same method. But inexplicably the oscilloscope trace remained flat. I have to investigate what was wrong.
I used 2 earths. One is that of the house, that comes with the electric plugs. The other is the earth for a shortwave radio station (8 mtrs of copper wire buried 10-15 cm under ground). There is 30 ohm between the 2 earths. I don't know the distance.
The variac that I bought monday is very useful. I encourage all experimenters to use one. I have still a spark with only 75v.
My next step is to succeed in monitoring the output current.
Pirate88179
@ exnihiloest:
Please keep your photo sizes to below 800 x 600.  I have re-sized your photos in you last post.
Thanks,
Bill
baroutologos
@Exnihiloest,
Nice equipment. Cannot see the coil though? Perhaps starting taking measurements without a kapagen like coil, then adding one and see difference?
