Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 321 Guests are viewing this topic.
XS-NRG
Quote from: quarktoo on January 28, 2011, 05:52:02 PM
Do you know how to generate cold electricity?
Yes, you put your battery in the freezer for at least 30min.
Then take it out and power your load with cold electricity  :)
quarktoo
Quote from: XS-NRG on January 28, 2011, 06:06:49 PM
I like dole's idea better. He says it is a standing wave - absolute electrical symmetry. Although your method sounds much more simple and definitely safer.
quarktoo
Has anyone figured out TK latest pump thingy? It sounds like the magnetohydrodynamic effect Stan Meyer spoke of. I wonder if Tesla used that effect to drive his turbine but didn't speak of or patent it?
Herger
Quote from: XS-NRG on January 28, 2011, 05:47:45 PM
This is not true.
You can only have Cold when there is no electron flow.
Since conventional current involves electron flow Cold cannot exist.
This is why it happens prior to electron flow and dissapears when mass starts to move.
Grumpy would know this  ;)
This is not true, but it sure explains a lot.
The effect before the electrons drift is not cold electricity or cold current.  This is the wave effect, for lack of a better term, that can cause current flow under certain circumstances.  This effect can cause cold current, conduction current, or both and this depends on the orientation of the forces involved.  It is this effect that produces the perceived gain and any cold current is just a bonus unless it causes problems and then it is a nuisance.   Conduction current is electron flow. Cold current is outside the wire and is something else, so you can have both like I said.  If you have both, then a measure of the conduction current will not indicate the correct amount of current which will be much higher.
I always thought that the frozen wires on the VTA when it was shorted was BS.  If not, I would sure like to see that.
Too see the effect, just pulse DC HV into a big spool of wire.  The shortest that I have used is 1200 feet, and for test I have a coil that is about 3000 feet.  Use at least 2kv dc and fast pulses.  If your pulse is slow then us a short gap to speed it up, some HV diodes work well for this when reversed.  You can free run your pulser but it is best to trigger some way so you an adjust it and find the good spots.  Some pulse rates don't work well at all and you will think the whole thing is BS.
Why are we going over this anyway?   Many in this thread already know these things.
XS-NRG
