Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 212 Guests are viewing this topic.
stivep
Quote from: Shokac on March 24, 2011, 03:52:08 PM
http://www.aes.org/aeshc/pdf/how.the.aes.began/vincent_magnetic-audio-fundamentals.pdf
Very interesting material. Thank you very much I respect you  SIR.
From me:
Take it for granted:
1.Tariel DID NOT USE ANY FERRITE!! in his coils.
2.Metal like pipes in 100KW( Turkey) are rapping tape (for parcels) in silver color.
3.These are pick up coils  ( no metal and no ferro-core)
4.The configuration you see in that video is NOT the working configuration in regards to details: where spark is and where spark should be.
Do not ask me how do I know.
Wesley
stivep
These are just helpful but not major.
http://www.freepatentsonline.com/2709225.pdf
http://www.freepatentsonline.com/2721899.pdf
http://www.freepatentsonline.com/2875412.pdf
http://www.freepatentsonline.com/3136960.pdf
http://www.freepatentsonline.com/2424977.pdf
http://www.freepatentsonline.com/2990516.pdf
Magnetic amplifier
http://www.freepatentsonline.com/2773132.pdf
Magnetic amplifier for inductive loads
http://www.freepatentsonline.com/2516563.pdf
Electromagnetic system
http://www.freepatentsonline.com/2329021.pdf
Converter system no diodes used for ractification!!
http://www.freepatentsonline.com/2199121.pdf
Rectification of alternating currents
http://www.freepatentsonline.com/1857160.pdf
Electrical-current modification
http://www.freepatentsonline.com/1679448.pdf
for magnetic amplifier:
Variable reluctance transformer
http://www.freepatentsonline.com/2686290.pdf
Magnetic testing apparatus and method
http://www.freepatentsonline.com/2440984.pdf
Magnetic amplifier with condenser discharge control circuit
http://www.freepatentsonline.com/2850696.pdf
Amplifying apparatus
http://www.freepatentsonline.com/2247983.pdf
Magnetic device this one has means of "memorizing" energy
http://www.freepatentsonline.com/2164383.pdf
At most these are interesting and important informations about magnetic amplifiers and correlated devices.
Magnetic amplifiers where competition to tube and transistor amplifiers the further improvement sized  in 1954.
Performance was equal but in some instances better than tubes and transistors of its time
The rigidity and dependability  af the concept is outstanding.
The power handled over million Watts was not unusual and very often applicable .
Wesley
PS: TK should be understand as valve that  release energy.
like valve of the water pipe. Small amount energy controls the big one
At this point magnetic amplifier  has the same application
scratchrobot
@ Wesley, how do you know? :)
Thanks for the links, you are saying the magnetic amplifier is only used to control and not to amplify?
Scratchrobot
grizli
Quote from: stivep on March 24, 2011, 06:55:18 PM
From me:
Wesley
This pipes could easily be shunts ?!
what is rapping tape ?
stivep
Quote from: grizli on March 25, 2011, 08:10:24 AM
That what looks like big metal pipes (3 of them) -there is no metal and pipes are not pipes.Tape used typically to rap the parcels before you send them make an impression that  you see metal tubes.
Wesley
