Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
baroutologos
@ The TK replication team,
It seems you work non-stop. That is good. One vid is succeeded by another.
In the last video of especially at the end, Arunas gives a small presentation about the overall concept. its a good rough presentation, but in order to get anyone his hands dirty in the lab bench, it should be useful to make another vid with hyperlinks on materials etc that will go step by step to the whole procedure with the nessesary tuning required as well.
Anyway, few practical questions cross my mind as:
Using the two generators + Hv source (for sparking and energizing the bright or sheld) a question of paramount importance comes to me.
How the two generator - the 50Hz carrier wave ( i suppose arbitrarily chosen so as to mimic 50 Hz mains) and the tunable 200-600 Khz ramp generator as as to modulate the carrier wave are not BURn out due to excessive voltage rise when the generator works?
In other words, if the biffilar inductively coupled (to the other part of toroid) output winding is able to have as much as 200 or 300 volts in order to run those incadescence loads that you have shown and usually are powered by mains,  the primaries (especially the ramp generator winding (with 1 : 2 analogy to output winidng) it should be take as much as 100-150 volts effectivelly destroying most signal generators.
How that is not happening?
Thanks.
ps: lets get technical ;)
FreeEnergyInfo
http://freeenergylt.narod2.ru/aidas/
PLYZ POST...
COIL  1  =16 TURNS ????
COIL  2  =51 TURNS ???
COIL OUT  = 150 TURNS ???
CONECTION SCHEMATIC COIL ...
PLYZ POSTED ORYGINAL SHEMATIC 800/600 PIKSEL http://freeenergylt.narod2.ru/aidas/R.bmp  ....
Shokac
Quote from: stivep on October 30, 2011, 05:47:16 AM
I was afraid that they shut down the forum...
Sorry for my comment on the video I have had the worst thoughts.
Working OU wake up. We are the People Save it now!!!!!
http://www.youtube.com/watch?v=gbeseiPPCeM
Wesley
Thank you Aidas and Arunas
Wesley
What TK said about this?
I am afraid this is not a replica TK. You've made a replica of a TPU or SR device
TK said that his device has no core (ferrite, etc.). ???
wattsup
@Wesley
Thanks for the new vid. I will look into the yoke as I have some here. We had done some testing with yoke cores when @otto was here. I remember mine got so hot it burned a permanent marks on my desk. Still there today. lol
@All
I put some images of my Caduceus Coil build.
What I did is to put the inner coil on a separate cone so I can slide the outer or inner coils to see if this helps find the best transfer point. I also connected the five inner CC winds with separate wires so I can eventually try them in series or other configurations. It will also permit me to modify the inner Caduceus wind if required, so I have full testing flexibility.
wattsup
wattsup
I can't put more then two images with Firefox. The (more attachments) button does not work in Firefox.
