Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 221 Guests are viewing this topic.
elementSix
Maybe he puts the negative thru the left side and the positive thru the right side and the ground in the middle????  Any thoughts
wattsup
Quote from: a.king21 on October 25, 2012, 02:44:25 PM
wattsup:   So radiant energy is difficult to contain.
So you need to insulate with:
epoxy resin,
polythene,
plexi glass,
polystyrene,
etc.
Oh and you also need a great earth, the wetter the better.
@a.king21
Today I ordered my 8' copper rod and will pick it up tomorrow. Copper is so expensive these days that the dealer was sending his stocks to the recycler and was getting more money for it then selling it as a finished rod product. Cost $100. I just went to get 60 feet of #6 grounding wire so this weekend I will install my isolated Earth ground.
@xenomorphlabs
Thanks for posting that circuit but I think that one will only pulse one side of a coil. I think we need to pulse both sides of the coil. If you see a circuit or if anyone has a simple enough circuit that can to this, please put it up.
@verpies
Before we were interrupted rather abruptly, we were speaking about how to use the two transistors that I am putting here again to back track.
Quote from: wattsup on October 24, 2012, 03:53:06 PM
@all
The only main reasons I could think of to use two transistors of that size would be too.....
a) pulse both the negative and positive sides of a primary coil, or,
b) discharge both sides of a capacitor into a load.
For A, the reason to pulse both sides of a coil would be to pulse a primary in a way that you will not have a permanent connection on one side of the coil that produces a constant bias to the negative or to the positive. If both sides are released at the same time, then the flyback will have nowhere to go but out of the coil and be released to the secondary with greater punch.
For B, if you had a way of using simple capacitors and diodes that take an AC signal, send the positive of the wave to one capacitor and send the negative of the wave to another capacitor, that's two caps filled to the voltage peak (not peak-to-peak), that can then be released by the two transistors where the caps are now in series to double the voltage or in parallel to double the amperage.
So if you or anyone knows about a circuit that can do either A or B, I would need that to make some more tests.
Also some were referring to Tesla tests of sparks creating stinging effect on the body. Do you realize what size or strength of spark you need to do that? The noise alone would render you near deaf. There is no such strength in the TK spark. It is a small furty spark that has no punch, let alone creating any coupling event as I have tried that for days and days under so many combinations and frequencies using the same 6 turns coil with a TKc inside topology. There is nothing there but a token coupling event that barley starts up the filament of a 7 watts 120vac bulb only at resonance of around 21.5kHz. Ground, no ground made no difference.
@andrea76
Thanks for putting up that recent post. We should not forget it, especially the part where TK was sad that the 2004 video was published. This means he was using much less decoys in that one and the only real decoy being the spark gap that sadly (or happily in our case) froze up during the demo. Also,I am sure he never counted on so much attention but it has been a long road from all the analysis of all the videos and all the damn commotions did not make it easy at all to keep the concentration steady. But I think we are close.
@Zeitmaschine
Yes it is around that time as well. All this just bounced so fast.
I think we really need to look at the A and B conditions above using two transistors and anything else required that could fit inside the tin can.
I remember way back when we would use a battery with a parallel primary coil that would be manually shorted across the battery, this would send great voltages out of the secondary. I could be possible that the two transistors are doing just that.
Take the 2004 device again. The open transformer secondary with greater amperage then the primary is rectified. Why do you rectify it when your output is AC to load? Well you use the DC side and that visible capacitor in parallel to the DC output of the rectifier and you now have a battery. Then you send each side of that DC through the transistors and use the TKc on each side plus the load to the short the DC.
The question then remains what is that AC5 line doing? I think I know. Shit. Because the AC5 lines are so thin, all he is doing is sending that AC low amperage to the primary of a small HV coil inside the tin can TO PRODUCE HIS SPARK DECOY. All the parts would fit perfectly in this scenario. Man oh man.
We are really not that far away.
wattsup
elementSix
@a.king21
If you have a Scrap recycling yard near you,  I buy tons of nice wire, copper sheeting and anything else you would need at alot cheaper prices.  They pay 2.50 a pound and you can buy it from them for like 50 more cents a pound.  Its a lot better than paying retail..  I live in CINCINNATI so there are 4 of them I can go to and all the Junkies and crack heads sell what ever they can find or steal from their work.  Makes for really good wire ect...
elementSix
I hate to sound like a neewbie, but I have a MOT and I hook one of the output wires to a BIFILAR pancake coil and when I do this, I get more energy it seems from the unused wire than the one wire I have hooked up from the MOT..  Is that just displacement or transference???  Because it arcs to my finger with a stronger sting than just the one wire from MOT itself
elementSix
KING Said that TK didn't mean for the 2004 video to go out.  That should be what everyone concentrate on.  When the guy who is filming pans over to the work desk and you see 4 or 5 black disks that look like iron powder.  They look about the same diameter as the can at the end of the coil setup.   Could he be using the disks with bifilar coils between them.  That could be the reason for all the wires running into the back of that can from every part couldn't it???   Just trying to help...  There are 5 or 6 pages of TROLL attacks on each other and the fact that anyone who honestly wants to fight the good fight, could waste their time arguing over  trolling-is, is  beyond me..   Focus Focus... 2012 is almost over and if we don't help each other out, we might not have another chance..  Troll are only hurting themselves, their families, the planet and the human race.  What will be your punishment when God asks you why...
