how does a heat engine actualy produce electricity???
Started by Hydro-Cell, July 12, 2009, 02:34:59 PM
the_big_m_in_ok
I remember in passing the next day, concerning the Seebeck Effect, there seems to be an EMF being generated, since a compass needle can be influenced by the effect, thus indicating a current and magnetic field generated by that current, being responsible for the phenomonon.
With respect to a 'heat engine', Brayton invented a piston engine that gave rise to the famous "Brayton Cycle", even though the name is often associated with turbojets today. Brayton never generated electricity with his machines, but it's certainly easy to do from a power takeoff crankshaft connected to a Brayton Cycle engine.
lumen
For a description of operation of the most efficient heat to power converter check out the JTEC heat pump.
http://www.stevenashley.info/2008/01/jtec-may-bring-60-efficiency-to-solar.html
onthecuttingedge2005
If you combine Thermal Solar Cell Tech with Aerogels you will have a Thermal Solar Heating System approaching 99.9 Percent efficiency at converting heat to Electricity. with Aerogels one can heat an entire house made of Aerogel with a single candle power of energy.
there will be many types of Aerogels but I wanted to point out the potentials of a technology that will come to replace just about everything as a super - natural substance.
the aspect here is that a perfect energy conversion system has no moving parts and makes no noise converting energy from one form to another.
so if you want to become an energy guru, I would get a degree in scientific methods of Aerogels and the manufacturing of such materials.
literally, think "Green".
no hype here.
Jerry ;)
