Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
Cosmicfarmer
Wow I take a nap and 5 pages get posted :-)
This forum is flying.
I apologize for not reading the stubblefield forum, but keeping up with energetic forum, Youtube, AND this forum is more then a full time job!  That, and I am moving to japan shortly.
I think the trick is to take a ground sensor's signal, pass it through an amplifier and flyback transformer (you pay the power), and then broadcast that back into the ground how ever you like. The signal will be in phase with earth, and when 2 signals are in phase, energy transfer happens. So imagine all the energy DEEP DOWN that there would be no way you could get at with the deepest pipes... is now in your machine's circuits! So, any metal in the ground within a large distance will have immense power, volts and amps. (maybe?) You will be putting back into earth its own signal, amped. This is what I imagine the magnifying transmitter was. Almost reverse of what people are trying here. Most ideas I have read so far (sorry if I havn't read them all ) are passive systems and are showing incredible results, but I have yet to see an active system like I said above.
That EER Tower idea which shows increased power in the earth is groovy, your are one step away from making the coolest ground powered flashlight ever. All you need now is a ergonomic case. Even have a + and - plug for charging batteries... but then you need a charge controller... bah
"No More Batteries EVER! You dont even need to SHAKE IT! Just dig a hole, put (product name) in the EARTH, and in 10 minutes you will have FULL POWER!! No more poisioning the sea with chemicals! No more over expensive batteries! "
I would call it Ninja Light, because its quiet and stealthy.
jeanna
Quote from: Pirate88179 on August 05, 2009, 02:49:16 AM
Smokey:
This is interesting as I have never tried multiple neg. electrodes.  I actually have two positive electrodes on my set-up now (for about 1.5 years now) and I got an increase in both volts (not much ) and mA's. (pretty decent increase)
What if you had 1,000 paper clips out there?  2,000?  I believe you can solder to a paper clip right so the hook-up would not be that hard to do.  I would like to hear Jim's view on this.
I think I tried this on both sides a little and I have 2 right now, one being a NS coil, but
It never in the world occurred to me that some thin pieces of wire would be enough. Here I am the minimalist in the crowd, at I sure missed this one.
Thank you Sm0ky2
I will cut some wire and solder it together for the tops and solder the tops to a wire to add to the EB. So much fun... what a great group!
Thank you,
jeanna
jeanna
Quote from: electricme on August 05, 2009, 06:32:11 AM
Last one for the night, Video 3
I have removed the LED off the series EER cells.
Both scopes now show identical waveforms.
jim
Excellent work jim!
I was about to post that I thought it was the led smoothing out the wave and there you did it!
I have watched a spiky wave change to a smooth one a lot like the one you show, when the leds are in the circuit many times (not all times, though) while looking at joule thief secondary waves.
Nice work!
BTW
jim and Bill,
I made those ultra short videos in raw format which makes them enormous. less than one second is what happens without compression.
Maybe "real player" can open up a .mov file without taking over your computer. If so, I can post little videos here that you can see. Would you be willing to try opening one I posted before in real player and let me know?
@cosmic farmer
I think you grocked something important.
I do not have a clue how to make an amplifier for this... unless Stubblefield did already.
I would like it if you could try this and do it before you get to japan, if possible. I do not think it makes any sense to use the power grid for this. a stand alone battery for amplifying and charging your EER is what would work.
It will be wonderful to have you be doing these things in Japan and adding them to this datalogging spot.
They do need to be uniform, however, so I am, also jim is using 2 different set-ups. One is a plain 2 probe setup to read the earth. (the datalogging experiment)
The other is my experimental one/ now 2/ perhaps soon to be 3!!
Thanks,
jeanna
Pirate88179
Jeanna:
I have removed real player from my computer entirely.  (That really took some doing let me tell you.)  I can't even watch Jim's latest ones.  I am hunting for the proper codecs to add to wmp.  Real Player is a virus and I advise no one to use it.
jeanna
Oh , no kidding I guess using a mac really insulates me.
MK1 offered this up a while back
http://www.videolan.org/vlc/download-windows.html
This is the link to the free open source player VLC
I don't know what it will open. This page is for w2000 but there is a link right there for earlier versions.
The cross-platform open-source multimedia framework, player and server
VLC media player is a highly portable multimedia player and multimedia framework capable of reading most audio and video formats (MPEG-2, MPEG-4, H.264, DivX, MPEG-1, mp3, ogg, aac ...)
FOSS !!!!  :D
I am just wanting us all to be sort of undivided, you know.
jeanna
