Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
sm0ky2
nice find Bill.
kind of goes along with my newest discovery..
i had my capacitor (4.7mF) in parallel with the earth battery, and i as i was messing with it, i noticed the 19 LEDs flashing randomly..  eventually i figured out that it was the act of connecting and disconnecting the cap that sent a power surge through the base resistor and triggered the transistor.
a feat the EB by itself is unable to do.
further experimentation revealed that if i open the positive end of the cap and leave the negative connected to the North side of the EB, that it draws more volts from the AIR than the south side of the EB can charge it.
so im going to experiment with this further, and connect a large array of open-ended capacitors to the north side of the earth battery.
i'll post my results later tonight.
it must have something to do with the single charged-plate drawing an opposite charge from the environment, because the north side of the EB by itself does not register any voltage difference, with respect to AIR.
[Edit:]  Wrong again i am........
i must be picking up some kind of spike-back from the JT coil.
its only occuring when i connect then disconnect the cap from the positive side of the JT. reconnecting again turns on the JT, and lights the LEDs for a moment...
guess i need some sort of switching mechanism here to further experiment.....
altrez
Monday July 27 2009 7:00 PM Western Kentucky.
-Altrez
IotaYodi
Decent voltage altrez. We had a good rain today and I checked mine at about 8 pm. It was 67v. Thats the lowest Ive ever seen it. Its usually around 89 to 98v. It always goes down when its wet. I went out to my pasture for kicks to see what my galvanized Anemometer mast would show to copper. It was only 48v.
What I know I know!
Its what I don't know that's a problem!
altrez
Quote from: IotaYodi on July 27, 2009, 09:05:36 PM
Thank you. I am thinking about moving up to a bigger piece of copper to see if I can brake 1v =) That's my goal anyway. Then I am going to run the leads inside and see if I can fill a super-cap. And then run my JT. It seems like to me anyway that when the earth is dry I get better performance as well.
I think extra moisture in the ground eats up the waves of energy that we are picking up.
-Altrez
sm0ky2
@ Altez
How far apart are your electrodes?
i have yet to break the 0.68v barrier with mine
i spaced it out to 7ft or so, but no gains as of yet.
its about to storm here and it seems as if the amplitude of the carrier waves is increased, compared to what it was when no storm present.  the DC base voltage is still the same, but the tri-waves im picking up are going crazy...
