Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@ Oscar,
Very many many thanks to you, and thankyou for the post, you are very welcome to join us here if you wish to.
Quote from: oscar on August 02, 2009, 09:19:07 AM
Hi electricme,
first of all thanks for posting the details about your series setup.
I also started experimenting along those lines (rod in tube cells) and never succeeded in serializing due to "leakage". I saw the voltage going up when putting my cells in series, but additional cells only gave approx. 20 % gain to the total voltage. Never been able to achieve the full 80 to 100% addition,
until you did it and explained it and the document of weri
http://www.4shared.com/file/92366887/ad3b1eb6/Free_Energy_-_Free_electricity_From_The_Earth.html
was posted.
However, I am now in the process of taking all cells out of the earth (in my case a sand heap left over from building), putting now each cell in a separate bottle filled with soil/sand (tried plastic and glass bottles, both work).
I think that is a good idea, as it seems to work and there is no leakage possible and you don't have to insulate the pipes with tape, as the bottle serves as the insulator.
Can put the array of bottles anywhere you like (on a table ...), it still works.
I am convinced (but may be wrong) that its just the interaction of the earth magnetic field with the dissimilar metals and the soil (I use sifted sand, moistened with water and vibrate the bottles while dripping water over the sand in the bottles, so that it gets really dens and solid)
Thanks for everything.
PS But must admit that I am only measuring open circuit voltage, so am not sure how much current there would be available from a "desktop EER".
You on the other hand could compare it directly with your system in the ground, hint ...,  hint ...,
edit: no metal (electrode) should be allowed to touch the bottle. Do not push electrodes fully down to contact the bottle base. All sides of the rods and tubes must be surrounded by soil/sand.
I think this series system needs much looking into, it certainly is an amazing EER system.
What you suggest above is very interresting, I will have to try this sometime, but if anyone is reading this, and was thinking of making their own EER, well I recomend anything just at the moment.
Oscar, I don't know if you have notice this, but sometimes the energy in my cells seem to disappear along the chain, then reappears, but if I measure the dead cell, it is actually alive, so I don't know, its a mystery to this kid lol.
Sorry about this late reply, I have been outside planting a new row of Aluminium outers with Copper inners, during this process, my next door neighbour decided to come for a look see, so I showed him my new baby 7 working, his eyes popped out of his head when he saw the HB LED working.
So after a huge explanation, all the whats/whys and hows, it was time to give my new ally 12 a drink, oops, I drowned them, too much water.
Oh well, I am learning this stuff.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
electricme
@Bill,
Thanks for the bucket idea, I must take a look for this.
Quote from: Pirate88179 on August 02, 2009, 02:13:38 PM
Jim:
I like your PVC idea.  As a matter of fact, think about this, if you lined the inside with one type of metal and the outside of the tube with a dissimilar metal and buried it in the earth, not only might you have an EER but it is also a capacitor.
There is a youtube video where a guy makes a huge capacitor out of a 5 gallon plastic bucket by lining the inside with foil and the outside with foil.  He charged it up with a Vandegraph and got some huge sparks out of it.  This is very similar to the film canister capacitors that have been posted on youtube as well.
This might be very interesting as not only is it creating a potential, but storing it as well.
Lots of stuff to explore here.
Bill
I think we just scratched the surface here, theres a lot more to go.
jim
electricme
@ Cosmicfarmer,
Welcome to the thread.
Quote from: Cosmicfarmer on August 02, 2009, 08:36:57 PM
Yay first post for me  ;D
Allright I set up a worthless earth battery and tested it out, I know it wasn't entrained. I no longer have constant access to the earth, even though I easily could. Pipes in the ground are eye sores and get me yelled at, but I persist.  I set up this E-B on the sneak-tip and these are the videos I made. Nothing eye-raising.
I also made a basic stubblefield, buried it, and probed it. On the video, the 4 connections from the large white wire are the diffrent ends of the stubblefield. It wasn't finished but my window of opportunity at the ground was short. Same signal as all my other grounds.  I think that whole area, even being in the mountains, was saturated with nasty grid vibes.
http://www.youtube.com/watch?v=si9pSset1_s
http://www.youtube.com/watch?v=c8U4_Ur5M64
3 foot copper north, 1 foot zinc south. As soon as I was finished with the experiment I had to unearth them. I know the magic in an earth receiver is letting it get entrained and observing it, but I could not leave these pipes in the ground.
One thing to notice though, is I had a rectifying capacitor (2 reversed diodes with common leg, to both sides of cap) to store the charge. Putting the ground on the - side before the diode reverse-charged my electrolytics .5 volts, and after the diode normal charged up to ~2 volts.
Also.  When I had the scope connected and was watching my circuit charge up, it took 40 seconds to get to ~2 volts. When I took the scope off but left the grounds alone, the circuit would not charge past .3 volts! As soon as I hook up the scope, up it goes. Scope alone did not charge the caps. Ground alone didn't get max charge. Both combined were necessary to bring the caps up to over 2 volts.
So, was this effect some sort of grid noise that the scope brought to the capacitor, which it rectified? (scope alone did no charging) or was this the ground energy being "monitored", and by the act of monitoring it, volts increased for me?
The ground signal was about 3 volts 45 hz clean looking AC. I even turned off all my house power at the breaker except for the scope and it was still clean AC. My signal (oscope to finger) was about half a volt, same frequency AC as the ground, but inverted. My bio-signal was the same frequency as ground but inverted. Also there were complexities in the wave that reminded me of fractals... but my scope is too old. Also touching house ground would null my signal, and earth ground gave me more volts but reverse phase. Just watch this video.
http://www.youtube.com/watch?v=0l9MLULqC38
Anyway, I am still on the hunt of a living accommodation that lets me put some metal in the ground. When that happens I will have scope to ground 24/7 and webcam link for you.
Previously, I was at a place where I had about 6 ground rods of different metal in various places and I saw similar waveforms as the ones earlier in this thread. That ground was entrained. I have never repeated it since. I took no pictures so I guess it never happened (to you).  This was before I knew about the data collection en devour on this site. The frequency was in the Mhz and about 11 volts.
One thing to think about - I have had more success using ground antenna (one rod) then the zinc/copper pair. Anyway. I got more experimenting to do and will post something when I think its relevant.
in the mean time, peace out.
Dont worry, we all have to begin somewhere,  I still remember my first post, which was incidentally a PM lol.
There is a lot of info you have submitted here, I will have a second look at it shortly, so far its quite interresting.
Bill and Jeanna and others will be interrested in the Stubblefield work you have done.
cosmicfarmer, now that is a quaint avatar, you haven't been raising green cheese moonwize?  ;)
jim
Cap-Z-ro
A quote from Ed Leedskalnin:
" I made a lot more electricity with steel than I ever made with copper."
Regards...
electricme
@Smoky2
Happy birthday for the kiddy
Quote from: sm0ky2 on August 03, 2009, 12:04:49 AM
kid had a borthday today, so i obtained more of those toy-twist-tie thingies.
i went ahead and plugged my large steel pipe back in parallel with them for extra current boost.
i now have 13 of my "experimental electrodes"
(+ a 2ft stainless steel pipe)
and 3 6"-square copper plates at the south end.
drawing 0.98v @ almost 6ma now.
if i can find a suitable substitute for these things i would like to make a field of hundreds of them. i think great current can be drawn this way, by connecting several more of them in parallel.
i can light up all of my 30 LEDs now.
caused my neighbor to ask what it was tonight !!!
Ha ha, must be a thing for neighbours, I had a neighbourly visit today.
keep us posted with your EB output, any output is better than none.
jim
