Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@ cosmicfarmer,
Ha ha, I also have noticed this, just try 4 days away and see what happens, now this is experience talking, lol
Quote from: Cosmicfarmer on August 05, 2009, 01:56:54 PM
Wow I take a nap and 5 pages get posted :-)
This forum is flying.
I apologize for not reading the stubblefield forum, but keeping up with energetic forum, Youtube, AND this forum is more then a full time job!  That, and I am moving to japan shortly.
I think the trick is to take a ground sensor's signal, pass it through an amplifier and flyback transformer (you pay the power), and then broadcast that back into the ground how ever you like. The signal will be in phase with earth, and when 2 signals are in phase, energy transfer happens. So imagine all the energy DEEP DOWN that there would be no way you could get at with the deepest pipes... is now in your machine's circuits! So, any metal in the ground within a large distance will have immense power, volts and amps. (maybe?) You will be putting back into earth its own signal, amped. This is what I imagine the magnifying transmitter was. Almost reverse of what people are trying here. Most ideas I have read so far (sorry if I havn't read them all ) are passive systems and are showing incredible results, but I have yet to see an active system like I said above.
That EER Tower idea which shows increased power in the earth is groovy, your are one step away from making the coolest ground powered flashlight ever. All you need now is a ergonomic case. Even have a + and - plug for charging batteries... but then you need a charge controller... bah
"No More Batteries EVER! You dont even need to SHAKE IT! Just dig a hole, put (product name) in the EARTH, and in 10 minutes you will have FULL POWER!! No more poisioning the sea with chemicals! No more over expensive batteries! "
I would call it Ninja Light, because its quiet and stealthy.
I think everything you mentioned above has some merit, good thinking and have a safe trip to Japan, don't forget to login here when you are able to. ;)
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
electricme
@Cosmicfarmer and Nightshade,
Thankyou for the Grandfather stuff, TA, cool too.
The parents called him Zachary Orsome .....surname will have to wait lol.
This is my 5th grand kiddie, but there is happennings down the road with the little fellow that I am not happy with, carnt say any more just yet, if you pray, start prayen.
jim
nightshade
Jeanna
you have some interesting thoughts there concerning those fractuls at
different frequencys your seeing could chaos theory be involved here at all ?
I havent tryed inductors yet on my eer setup but have used potentiometers
resistors good for verying voltage on eers
Pirate88179
Jim:
Happy Grandfather day down there!  Zachary is in my prayers.
Excellent work on your EER voltage increases. Run that through a JT circuit and look out for the sparks.
Bill
jeanna
Quote from: nightshade on August 06, 2009, 10:36:04 AM
Jeanna
you have some interesting thoughts there concerning those fractals at different frequencies you're seeing could chaos theory be involved here at all ?
Hi nightshade,
First I want to appologise for calling you nightlife! and welcome you on your own merit!  :-[
Is it still called a theory?
I think it is a mathematical way to express what is seen in nature. I remember that theory was very hot in the late 80's early 90's. There were photos of the julia set in every magazine.
It is also a favorite with the crop circles makers. They come in and poof a julia set has appeared on the crop field.
But what I am talking about is how they repeat at repeating intervals. And I think it is not doubles in all cases either.
At first I thought I was seeing a simple harmonic, but when the same design figure appears way inside another figure... I call it fractals, like, for instance, the julia set.
QuoteI haven't tried inductors yet on my eer setup but have used potentiometers
resistors good for varying voltage on eers
How have you used the pots?
Except for the fact that the stubblefield generator IS an inductor, I haven't tried that either.
I am think little ones to take advantage of the very high frequency then adding ... I am quickly trying to learn about inductors asap.
In the first youtube video I was showing the little green NS generator because that is the one I had in my hands when I turned on the joule thief and saw the scope come alive.
That has an additional pair of inductors wrapped around a couple of free wires.
As detected by a DMM, the one wrapped around the iron wire shows an increased voltage difference when compared to (I think it is ) the center bolt even when that is not in the ground.
I need to re-read my notes from last year.
I did things that I knew were important but at the time had no clue what they meant. This was one of them.
Thank you,
jeanna
