Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@ Freepow
Quote from: freepow on October 21, 2009, 03:13:39 AM
:)Hello can someone help me ??
My 90 foot long, 6-7 foot high long wire antenna + my ground pipe connection gives me as follows...
5 volts (AC) and only .06 ma  NIGHTIME measurement
6 volts (AC) and only .13 ma  DAYTIME  measurement
When i use this to power simple joule thief it measures as follows...
3.1 volts (AC) and 2.6 volts (DC) and 3.14 ma NIGHTIME measurement
3.6 volts (AC) and 2.9 volts (DC) and 3.45 ma DAYTIME  measurement !
Why a higher voltage and current during daytime ? Anybody know why ?
Any way to raise current higher so i can light LED ?
This is free power that I am getting from this system !  Anyone tried this ?
The daytime vs Night time gives you the clue, the sun is the source of the energy during the night time, I think the energy is cosmic radiation, the length of the aerial is the key to this, if you know the frequency of the cosmic wave, convert it to a dipole length and you should be in tune with the cosmic ray.
Then put a series (read this is a number of antennas) of antennas up, in parallel to get amps out of it.
Trick is to see what happens under a fixed load, does the energy you get out of the single array disseaper under a load? if it does, then you need to lighten the load to keep it going.
Try putting a silicon diode in line with it and across it in turn, see whats the result.
Put a completly flatt battery acros sthe output, see after 24 hours if it got any energy put into it. Do the same with a capacitor.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
electricme
@Freepow,
Quote from: freepow on October 22, 2009, 06:30:25 AM
Can someone show me how to make a simple Earth battery (stubblefield) , One that has wire wound around it, one that gets at least 20 ma + ?????
(Grab a 12v DC wet cell car battery, through a wire around it) lol
Its not as simple as this, (wish it was though).
Actually, no-one has been able to come anywhere close to Nathan Stubblefields success, and a lot of research on the net has taken place by some very good friends of mine who can vouch for this.
You would need to make a start by reading both of these Stubblefield related forums, LocalJoes then read up on Pirate88179 forum, if you manage to last the distance, then you would have some idea of what we all were facing.
The joule thief forum began because of the frustration we all had, this tought us about toroids, winding techniques (bifilar) which are related to stubblefields coils, making and breaking circuits at the peak of the magnetic fields etc etc
Jeannas work there was and is legend along with all the others.
A key to understanding his work is to read up the patients stubblefield had, these will give you some idea of the material he used in his devices, replicate them, and wouldn't it be surprising if you got a result first off.
My personal view is, to really pile on the winds, make the thing so big and heavy that teleric currents will seek it out.
Put some pointy ends on the iron bar, long pointy ends, pointy ends concentrate magnetic fields.
Do you bury the things vertically or horozontally, looking at a patient, I see a vertically orented cell working better as the energy enters and exits it faster.
This may be a key to its operation.
One of the keys to making discoveries is to read up on all the notes relating to the topic you want to try.
Study the youtube images, try and see if there is something the poster has missed telling you in his post of them, all little bits of info helps.
Get a "feeling" a "hunch" and act on it.
This probably hasn't answered you question, but if another person reads it, try the above for answers.
OK for a start, get your self any lenght steel bolt, insulate it and wind on it in bifalar 2 sets of wire, one copper, the other iron, then put it in the ground, connect a meter to it and see if there is any energy.
If there none, try connecting the outputs in a different configuration, retest.
Keep going, keep doing this, keep testing and testing.
Try different size wire.
Try different size and length iron bolt
Stubblefield drove us to pulling our hair out, wanna join the mob? you are welcome, ha ha
Seriously, when this stubblefield device is working, when someone has cracked how to do it, it will be an amazing day indeed.
jim
electricme
@All,
Its time to pack up shop for a few more days, I still not well enough to keep at this for too long right now so I will be back in a few days to catch up.
Wow, this is good stuff, I have missed it.
jim
freepow
 :) :)  Jim, I have included a graph with just odd times of the day when I could measure it,
This is with my 90 foot long wire antenna for (+) and a galv iron pipe in the ground for (-)
what do you think it is...
Cosmic rays ???
AC power lines ??
Radio waves ??
freepow
I want to say, that usually in afternoon it drops quickly.
