Thanks to ALL for your help!!
a lightning bolt, is just water polarized by dirt and sunlight.
Started by nitinnun, July 22, 2009, 03:37:49 PM
nitinnun
negative dirt/sand/rocks, positively polarizes one half of the water.
positive sunlight/air/ionosphere negatively polarizes the other half of the water.
a vast cloud of electrons builds up, in the negatively charged half of water.
then violently moves into the positive half of the water, as electricity.
(once the electrons are built up enough, and the positive sun is blocked out enough, that the electrons can overcome the electrical resistance between sky and ground.)
it is not hard. it is simple.
polarize the water with a positive material and a negative material,
and let the electrons travel through your device, to become depolarized.
a pyramid or cone shaped physical structure, builds up clockwise and counter-clockwise magnetism.
which can cause water to polarize.
polarized water, might as well be a charged capacitor.....
newbie123
Quote from: nitinnun on July 22, 2009, 03:37:49 PM
Why is this in the News section?  This belongs in the half-baked or completely retarded section ..
Until you can measure it, arguing about something can be many things.. But science is not one of them.
onthecuttingedge2005
May I help with this matter.
if you want to know what the symbology of the pyramid is then go look at the NIF or National Ignition Facility, you will see a very large Crystal Pyramid there for the LASER Process.
here is one that would be processed for the LASER system.
https://lasers.llnl.gov/newsroom/project_status/2008/june.php
there may be other uses but that is just what I know.
Jerry ;)
