Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
the_big_m_in_ok
#6,970,141
One loop inside another.
#6,025,813
A loop system including output circuitry.  Can be made parallel to the ground and very large.
#1,471,165
A Wimshurst generator combined with a radio receiver:
http://www.google.com/patents?id=SZleAAAAEBAJ&pg=PA1&dq=loop+aerial&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
the_big_m_in_ok
the_big_m_in_ok
#5,373,301
Square, crossover elements for a transmitting/receiving antenna.
#4,873,527
A loop antenna, ferrite core and two capacitors in series with the wire.
#4,441,498
This is similar in function to #3,686,389.  Four bifilar coils in series(Fig. 4).
#3,918,063
Fig. 4 looks like #2,229,984.
#3,750,180
This is different.  An antenna that might also be used in a Joule Thief as a specialized transformer.
#3,683,389
This is strange.  Two 90 deg oriented coils inside a larger flat loop antenna.
#3,390,394
This one has the coax cable as the antenna.
#2,910,695
Direction-finding antenna that looks like a theft prevention antenna.
#2,709,219
Like the French patent for free energy involving iron, merely as an antenna.  Might be combined with that patent?
#2,273,955
This looks like a Stubblefield setup.
#2,229,984
Circular antenna with air core coils.
#2,203,517
Looks like #2,273,955.  A radio receiving antenna.
--Lee
the_big_m_in_ok
#2,292,182
Fig. 4 is probably the most relevant.
@Jerry(onthecuttingedge2005)
This is a coil application you wanted to see if I found one like yours.
#1,372,850
Slightly off topic?  This is approximately an influence machine with a disc and coil attached, touted to have use as a signal radio generation application.  May be modified to a Wimshurst machine.
--Lee
