Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
onthecuttingedge2005
Quote from: xenomorphlabs on August 23, 2009, 05:50:26 PM
Yes the secondary seems like copper litz. I have bought something in a store that looks exactly like it. (It is more suited for RF signals)
The questionmark device might contain inductors (probably two of them) but since this seems to be NOT the output transformer (because too small for 30 kW) i can not
identify its function and what might be inside.
Don Smith refers to it as the feedback system on his website, however it seems not to be wired to the primary-side inverter. So maybe he talks about another feedback than to the primary ?! Something that might contribute to the secondary functionality maybe even ???
Hmm, so you also think that the two little components could be resistors, that was my first thought, but i could not explain their presence at that place in the circuit would it be resistors. Or maybe also diodes? From just the appearance they look like smaller HV caps, something like in the 3-6 kV region and few pF capacity.
The fact that Smith paralleled two diodes in the bottom part indicates that he
has already quite some amperage flowing to the caps.
Nice that you nearly have all components together. Do you also already have comparable HV caps with enough power rating?
Looking forward to seeing your set-up soon ;)
The slidable primary can be seen in the 3rd pic.
Hi xeno.
it is very much like the MIT Physics Demo -- Resonant RLC Circuit
http://www.youtube.com/watch?v=ZYgFuUl9_Vs
Pretty interesting stuff.
Jerry ;)
Peterae
Yucca
Here's some info on the blocking mono 5th paragraph is the circuit i used, but tailored the ferrite core windings.
http://mysite.du.edu/~etuttle/electron/elect37.htm
I have used a line transistor to handle high voltage, i have found it to be ideal for producing HV pulses and because it can be triggered using a sig gen can be driven at different freqs.
It consumes very little current and runs cool.
It can be very hard and unforgiving driving LOPTX's, your driver circuit works great, i built mine 5 years ago now, i used a 555 with a pot to set the freq and used a novel fet push pull stage, it has served me well during lifter tests but the fets do run hot after a while so it's only good for 5-10 minuet runs.
Regarding you gap fire speeding up, Nice setup ;) i would be surprised if it is the cap getting hot but don't know the answer, maybe you are building up electrostatic charges in the room.
xeno
It's hard to swallow the KW's of energy that are being quoted for Don's device, i think the best course of action for me is to do a rough build using lower grade components as these are readily available but keep looking out for bigger and better components because this could take some time and money.
Looks like you are way ahead you've done a fantastic job with collecting information for which we are really grateful -- Thanks.
Is anyone familiar with the make of spark coil he is using looks like Bertonee?? but not found anything on google but not sure of the first letter
Cheers,
Peter
xenomorphlabs
@Jerry,
thanks for the link. I had watched all the lectures, but did not stumble about that experiment. It beautifully shows the tuning like in Smith`s device.
Quote from: Peterae on August 24, 2009, 04:06:33 AM
Bertonee are now called Ventex
http://www.ventextech.com/#neon!Energy%20Efficient%20Neon%20Power%20Supplies
Peter, thanks.
I usually try to gather as much info as possible before buidling something and since Smith is so cryptic about the functionality of his devices, i think it is most valuable to understand the principle before building something. Otherwise one doesn´t know how to seek errors and optimizations.
Quotei think the best course of action for me is to do a rough build using lower grade components as these are readily available but keep looking out for bigger and better components because this could take some time and money.
You are right, we all have a tight budget.
Kapanadze`s early devices would be cheaper to build compared to Smith devices (no expensive caps),
but unfortunately no-one has figured out yet how he manages to keep the resonance
when hooking a load to the output.
Smith solves that by storing the energy in caps and then converting to the desired AC output frequency/voltage with the output transformer which galvanically separates the load from the secondary oscillator, so it could not kill the resonance whatever resistance (inductance) the load has.
QuoteIs anyone familiar with the make of spark coil he is using looks like Bertonee??
Good job on finding out that Bertonee is now ventex.
I guess you meant Neon power supply when you said Bertonee spark coil ?
The particluar model on the table device is described by Smith to be
a 9 kV 30mA model (very likely solid state) with a neon dimmer attached to the side.
I browsed ventextech`s website and your new info narrowed the possible output voltage range for the constant burn 12V NST in the small suitcase model (1500-4000V, but more likely 1500 V)
http://www.ventextech.com/#gen4!12%20VDC
I am looking forward to replicating that one too, however i still don´t entirely understand the schematic since Smith indicates a DC out coming from the NST (?!)
and it is a riddle to me how the big cap bank is supposed to magically convert a high frequency to a low frequency without commutation of some sort.
Also the cap bank is stated to be made for DC  in this schematic too, which
contradicts the necessity of AC caps in resonant RLC circuits for the oscillation, so that the caps won´t get destroyed by the wrong polarisation.
Thanks again,
Xenomorph
Yucca
Hi all,
the change in output gap freq was definitely due to my input cap heating up, I tried swapping out for a cool cap and it started slow again.
