Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
NTesla
I have recently attempted to replicate his "Resonant Induction Energy transfer" device, as shown in some of his videos and documented at FreeEnergyInventions.com (that link may no longer exist).
No over-unity was detected.
My replication was close to IDENTICAL to the design shown in the video. I also tried various options including using a spark gap (SG) with varying gap size, gas arrestors (as shown in his video), different size capacitors, variable primary coil windings for resonance, and various input voltages and frequencies. In addition, different types of wire was experimented with, both on the primary and secondary coils - from plain enameled magnet wire, to HV insulated multi-strand cable. The secondary coil I generally used is identical to the one shown in the videos.
His use of gas arrestors instead of a variable SG is actually detrimental because the relatively tiny gap prevents a resonant charge build up on the capacitor feeding the coil.
The fact that he NEVER (at least to my knowledge) demonstrated a working device is telling.
I am close to 100% sure that this device cannot exhibit over-unity and therefore why would one contemplate his other devices given the erroneous nature of this device? There is nothing exotic or unusual about the circuit - it is essentially a Tesla coil setup with a lower voltage secondary circuit that stores the inductive charge in storage capacitors instead of a surface area toroid. Most people who have done any serious Tesla coil experiments will know that the secondary cannot provide over-unity.
a.king21
Hi, Mr provocative name :D
Zilano page 569 on the Kapanadze forum claims to have replicated Don Smith on the Energetic Forum.
As she's posting here, try and see if she will help. She says Don kept a couple of things secret. One is that the primary and secondary coils are REVERSED. So you might try that, it ought to be simple enough. The other thing which may let you down is the output transformer. Most people
use a microwave transformer in reverse, forgetting that the iron core saturates above about 100 Hz or so. I suspect the secret is in the windings, and I'm still learning. Try caduceus on output.
NTesla
Quote from: a.king21 on November 09, 2011, 05:55:34 PM
Do you have a link? Does Zilano have any pictures or video backing up her claims?
minde4000
NTesla,
Hey buddy. Nice to see you working with Don Smith device. I also have a complete system. I have managed to drive it with ~60khz 1.5-2KV sparks and have good earth grounding but I got nothing too. I did not even suceed in resonating primary due to severe impedance mismatch between HV power supply and primary tank LC. Could you post some pictures of your setup? You can find mine @ overunityresearch(dot)com under my bench. I think I need much lower impedance power supply... I also have 4 coils to choose from - 2 right hand and other 2 have left hand turns. I can make any combo out of them. Still got nothing so far.
Minde
Magluvin
Hey Minde and NTesla
Your secondary, is it 2 coils connected in the middle, 1 wound clock wise and the other wound counter clockwise?
This is something some or even most any not recognize in some of the drawings or diagrams out there. And Im thinking it is important.  ;]
Mags
