Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
xenomorphlabs
Peter,
you might be right there.
I have just asked me why Smith talks about the necessity for a 80 kV diode bridge in the diagram that you say yucca wants to build.
For some reason i also recall having read somewhere that one of these really was 20kV but i could be wrong.
Whatever hehe, i am sure yours will be good for a start.  ;)
Peterae
Lol xeno
I looked up the size of a 80kv diode and it was 120mm long
xenomorphlabs
Quote from: Peterae on August 25, 2009, 09:42:01 AM
Lol xeno
Well the big diode pair on the secondary in the image of the table device could be similarly long.  ;)
Also those were a custom part and they are not manufactured anymore.
The switching time was remarkably fast on them for high frequency.
The amperage through them was probably between 2 and 4 amps. thats why he put 2 in parallel.
So at 3 amps and 10kV for the cap, the output could hypothetically reach 30 KVA   ;D
Paul-R
Quote from: Peterae on August 24, 2009, 02:41:23 PM
The large grey capacitors are lower than 2500v DC because of the type and size of the terminals , i found a 4kv oil filled cap and it had massive ceramic insulation on the terminals
re reply #107,
Are you sure these are not the 2kv 1 uF caps in microwave ovens? If so, they are likely to have
a 1 megohm resistor connected internaly across the poles.
Also, if this is what you want, you should be able to carry off as many as you want from your
local recycling centre for nothing. Especially if you offer to bring back separated useful recycling
materials for their use (steel case, glass in door)
Paul-R
Peterae
Paul-R
All the microwave caps i have seen are not square in shape but have quiet rounded corners, These are Ex royal Airforce Dubilier Nitrogol caps probably deisned to be used in their UFO Fleet  ;D
Peter
