Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
mircea
Quote from: Peterae on November 28, 2009, 04:46:32 PM
Today i remade my Primary coil, i increased the diameter to just fit inside my secondary coil and i managed to use a full quarter wire length of the secondary in just over 5.5 turns so i should now have a pretty close match with regard to the wire length relationships, i will try resonating it tomorrow with caps.
Now in one of Don's videos he states that some Neon Transformers printed ratings show OU
Poynt99 stated to me this may not be the case, so i looked into this a little below are the specs of a Ventex NPS-12D10
You will notice at the bottom of the specs it has ** and says 'Equivalent brightness of electromagnetic transformer' so the print on the label is only an equivalent rating compared to a conventional transformer as opposed to this switched mode version which has an oscillating output of 20kHz, and therefore is not a true representation of power output from the module.
Another thing that occurred to me is that in the device i am trying to replicate don uses a dimmer to vary the 120VAC feeding the neon transformer, now i am not so sure this would work well with a switched mode psu based neon supply, it certainly wouldn't give a linear variation of the HV output and would probably cutout totally once a certain voltage is reached, in fact if the switched psu did it's job i would have thought it would either maintain regulation or cutout totally.
I am now wondering did he even power this up at some point OUCH.
Peter
Specifications
Input Voltage:    12 VDC (±10%)
Input Current:    1000 mA (Max)
Driving Distance*:
Neon:    1-10 ft, (0-3 m)
Mercury:    1-12 ft, (0-3.7 m)
Output Voltage:    3000V
Output Current**:    15 mA
Frequency:    20 kHz ( ± )
Operating Temp:    0° to 104°F
(-18° to 40°C)
Dimensions
Length:    3.0 in. (76.20 mm)
Width:    1.75 in. (44.45 mm)
Height:    1.25 in. (31.75 mm)
Mounting:    2.6 in. (66.04 mm)
Weight:    6.0 oz. (158.0 gr)
12 VDC Primary Leads:    8 in. (45.72 cm) wo/jack
Secondary GTO Leads:    18 in. (45.7 cm)
* Based on standard 12mm tube. Deduct one foot from driving footages for each pair of electrodes.
** Equivalent brightness of electromagnetic transformer
Hi,
Please send me the coils (L1 & L2) detail (yo5tx@yahoo.com), exact diameter, lengths, wire, etc. I want to see exact natural resonant freq.
giantkiller
luishan
Anybody more progress information about the Don Smith device ?
Nabo00o
I don't know if this has already been mentioned but the user armagedo0on has also done some experiments which have very close similarities to Don's devices. (Check out all his videos btw)
http://www.youtube.com/watch?v=lA87r58iCXo
The video speaks for itself, and it is Don's approach to the "normal" Tesla coil, with the primary moved into the center of the secondary. I do not believe the secondary is reverse winded from the middle though.
I'm just thinking if he had put a much higher voltage into that, he could have gone from miliwats into kilowats....
Replications are the key here of course, not talk, so I hope I will be able to supply the knowledge base with something as well with time....
Julian
Static energy...
Dynamic energy...
Two forms of the same.
