Selfrunning 3 KWatts ERR unit powering 3 x 800 Watt lamps
Started by hartiberlin, July 26, 2009, 11:08:50 PM
Harvey
Hi Stefan,
The device I viewed is the same one in the first video in this thread, the large black device not the smaller silver or yellow suitcase models.
I did not see any transformer, and if you look, you will see that just a couple of thick wires run down to a 3 outlet distribution box. Those outlets are just two wire ungrounded standard North American AC outlets. Tucked up inside on the left you will see a white block with a wound coil, it is thin. Somehow this is used to help control the system and I think that is part of the proprietary information that Dr. Schwartz cannot share with us. You can see the hinge pin for the lid, there is no way for any wires to go inside of it, there are none outside the case, so the only wires are those that run from the panels to the outlets. I suppose those 3 interlock switches (that shut off if you close the lid) could each be tied to a different RF circuit and each panel tuned to that frequency somehow...or even some sort of RF switch in the distribution box? That's a small box, I just don't think there is enough room in there, so the recievers would need to be in the panels somewhere. However he did it, those lights are controlled by those switches wirelessly.
The demonstration was not intended for skeptical analysis, so I did not take any measurements. I figured that time would come when they actually reached a point for public consumption. I suppose the voltage could be all over the map there, and as long as the duty cycle was short enough, the lamps would handle it. I didn't hear of any arcing in the lamps or the outlets, so I don't think the voltage exceeds the maximum gaps on those.
Cheers,
8)
Harvey
Quote from: Cloxxki on July 29, 2009, 06:27:13 PM
This is amazing. That suitcase would pretty much ruin the luggage capacity of my bicycle, but even really conservative speed estimates for 4 horsepower tell me I'll be needing a motorcycle helmet and suit! A professional cyclist won't last longer than half an hour or so putting out 0.5hp.
If the plates were placed inside the front triangle of the bicycle frames, aerodynamics would be served well, and there's plenty of room here and there for the various other parts. The electric engine can sit in the rear hub. Power will need to be applied very carefully. Even my legs make wheelies hard to avoid during a mountainbike race start, being a few seconds at merely 1hp.
Will this be attemptedly commercialized, or open sourced? I hope soon bicycle-sized units can be made somewhat affordably...
What weight would a unit be for a car-sized unit, compared to batteries? Unlimited mileage...
If I understand how this works, it is geocentric and will lose it's syncronization (referred to as 'grounding' in the video) if put in motion. So the best that could be hoped for is a battery charger when the vehicle stops for a certain period of time and is 'grounded' to that location. Look inside that box, its full of air ;-)
(Dr. Schwartz used the box to transport the lamps and extra parts all in foam protection, otherwise I'm sure it would have been much smaller).
8)
Harvey
Quote from: infringer on July 26, 2009, 11:40:56 PM
hrmmm... I wonder how they obtain the frequency to extract the energy from the ground I sure hope some of our ground or earth energy folks are looking into this it seems way too simplistic maybe real who knows ...
But from my observation the dress style looks a bit last century ...
Not to say folks don't dress like that today...
Also it looks as if it is a VHS dub just some simple observations but the more people laying claims the more people invest research into stuff like this...
Yes, we need some folks that are 'well grounded' in cutting edge theory regarding free electrons and their charge differentials.
Last century was only 9 years ago... :(, I have cloths that go back 20 years - (comfy ;) )
Not sure what they used to film it, but my copy is on DVD :)
8)
Macmep_L
Hello.
Even if you can make a device which will produce 100 watts, this is already enough to increase the power to ten times. I am from Canada, can I help you?
Well, I must say, I value the opinions of giant invisible rabbits much more than I do the average run-of-the-mill bunch of wild asparagus I read here. In this case however I have to wonder whether logic and proportion have fled...
It is impossible for me to say more than the obvious: the device as shown is impossible.
There are some questions that arise immediately: What is the true etiology--that is, does this Schwartz device really have anything to do with the original "elemental rod" device with the two rods that was shown lighting up a bulb? 74 and 75 elements, remember that one? Just a small device, no electronics or fancy LED displays. And the website seems to make a continuous link  between that device and this one.
Now, that device...was it for real? If so, being so simple, what happened to it? Why aren't we seeing lots of pocket elemental rod generators without all the fancy BS?
If it wasn't for real, yet came from the same people...
Well, the default conclusion is pretty obvious to me. Nobody (except Sterling) is beating a path to these people's door. And the Noah's Ark Foundation...that sets off a whole nother set of alarm bells.
Doctor of What, by the way? And from what institute of higher learning?
Inquiring minds want to know.
