Linear piston ratchet engine, 99% efficiency. Proto type in action!
Started by Tommey Reed, August 05, 2009, 08:34:22 AM
AlanA
I tried to pose my question once more:
10 or 12 PSI? Could this be real? This is a pressure less than the atmospheric pressure of about 14 PSI!
AlanA
Tommey Reed
I'm sorry, yes!
At 12 psi with an area of say 12in/sq or 4" piston, you will have 144in/sq..
Now the atmoshpere pressure at sea level is 14.7 psi....
So to answer your question about 12 psi, is yes.
12psi of compress air at 12in/sq piston area with a stroke of 12" will produse a total of 144 ft/lb for each 12" stroke of the ratchet engine, and a costant flow of 12 psi!
AlanA
1. May be there is a great misunderstanding or I have understood you wrong. I think a piston with an air pressure of 12 psi could no do some useful work.
2. I take your formula and did some trials. I reduced the stroke from 12" to 6": The result is a power output twice as with 12 ".
AlanA
Tommey Reed
If we us12psi to start with:
12psi = 12 lb of work at 1 inch of travel.
The Ratchet engine converts linear in to rotational energy, with the only lose of friction. At 99% efficiency.
If:
piston(a) 12psi at 12" of travel = 144lb of work...say 1 revolution
and:
piston(b) 12psi at 6" of travel = 72lb of work...say 1 revolution
For (b) to equal (a), (b) would need 2 revolution to equal (a)
a=144
b=72
a=(bx2)
b=(a/2)
Tom...
powercat
Hi Tom
I found this one on youTube, you might find it interesting
Worlds most efficient engine "The Edwards Winged Rotary"
http://www.youtube.com/watch?v=P6i4CVrcEJM
cat
