IST! NEO ZAP ARC REACTORS
Started by innovation_station, August 07, 2009, 09:03:50 PM
rave154
sorry for the multiple post here but i forgot,
i also have....
YUASA 12V, 7AH batts x 2
12V, 1.2AH batts x 2
APC 12V, 7AH batts x 2 ( but these are "dead", 5V on each or so, going to try to bedini them back to life today ) x 2
2.1KV caps x 2
15uF 450V AC cap ( motor starter )
220uF 400V ( from CRT board )
47uF 450V cap
4.7uF 450V cap
various caps assorted ( and resistors of course ) the full range
2N3055 x 9
TIP2955 x 4
BD912 x 3
BFY51 x 2
2N2222A x 4
2N5551 x 2
2N5401 x 2
IFR540A x 5
IRF740 x 3
also opto-isolators to hand
555's galore
mag wire, 20, 24, 28, 32AWG
8 breadboards
3 DMM's, 1 analog MM,1 analog ammeter(15A) and a scope.
just listing these in case you come up with any ideas but dont have a specific component to build it, then i can always throw it together on this end.
innovation_station
awesome bro your rock and were gonna rock this plannet called earth  ;D ;)
ist!   ;D ;D ;D ;D
rave154
i also have 4 of those curly thick wire thingies from the magnetrons which i saved, was gonna throw em away but i thought " nahh...i might just use em for something"...strange how fate works sometimes.
im itchin' to get to work on this.
innovation_station
im working on it bro ...
basically all my pwm curcuit is..... is a verry basic forced freq  jt with 1 single coil all im doing is rectifiing the fly back on the relay coil dumping to a cap ....  than back feeding into the driveing battery or tesla switch style driveing batteries  depending on configuration you choose
bedini  sm bla bla bla many many have used this trick in the past   wich tesla discovered...  and was understood by the old cultures ..
ok so i think it may be best with npn fets to only scoop the free stuff not use the on cycle to fill the cap ..  maybe a push button that FILLS THE CAP FIRST ...  to the driveing voltage ..
this seams to suit my usage ...  that way i took from the driveing battery enough to fill the ou cap to the the driveing voltage first then the first and following fly back will compound in that cap untill there is enough PUSH to feed back into the battery ....  ;D  and honestly with the push button i never took a thing from the battery i only shifted it to a cap and still have it on reserve ..
dont get me wrong the coil consumes power i dont care bout that tho ...
so it will return more and we will put it to work rechargeing batteries ..  this is only my driveing coil for my mechanical switches to switch high current!!
;D
william
rave154
cant wait to see a vid /  schematic * drooling*
