Maryland Company Buys 400 MW Free Energy Generator From BlackLight
Started by Omega_0, August 11, 2009, 11:35:05 AM
onthecuttingedge2005
A simple Palladium Filament or Diode can achieve the same thing.
Palladium's Affinity for Hydrogen separates the Hydrogen from the water molecule and the Heated Palladium Filament lets go of the absorbed Hydrogen because when the Palladium is heated to a certain temperature the bond between the Hydrogen and the Palladium becomes weaker thus liberating the Hydrogen for Chemical reactions with the Oxygen that was also liberated in the chemical reaction, Palladium is a catalyst to water and absorbs Hydrogen freely.
The Reaction of Palladium and Hydrogen peroxide can be very violent especially of high grade H202 of greater than 30 to 70% by volume, 90% H202 is very explosive when coming in contact with Palladium.
however H2O2 also reacts with Silver and is cheaper than Palladium so they choose Silver as the catalyst instead of Pd.
taking advantage of an elements affinity can be interesting to say the least but can be very dangerous if you don't know what you are doing.
from the diagram below I see they are using Sodium in the process, is there a detailed explanation of the entire reaction process?
I have 2 years of chemistry so it shouldn't be hard to understand and replicated the process.
Jerry ;)
mscoffman
Quote from: onthecuttingedge2005 on August 11, 2009, 02:01:51 PM
Jerry ;)
I started looking at historical information concerning the
Walther hydrogen peroxide engine. I noticed that concentrated
H2O2 was explosively unstable. It would explode by itself if fuel
lines were not 100% straight ie. as in bent around right angles.
Futher someone said this was due to *cavitation*.
Well, where there is cavitation and natural hydrogen, there is CF cold
fusion of the natural hydrogen isotope deuterium. Scientists tend to use
fully deuteriated systems as "DOOD" in their experiments. Using
natural isotopic ratios reduces the the rate of CF to lower levels but
it is still there.
My belief is that the Blacklight process is actually producing it's energy
via CF possibly during the "fuel" production process and then releasing
it later. This would be easily tested by varying the amount of deuterium
available to the process.
:S:MarkSCoffman
Omega_0
Today's news :
http://nextbigfuture.com/2009/08/rowan-university-publishes-further.html
Operating power systems using BLP’s chemistry, Rowan University professors have reported a net energy gain of up to 6.5 times the maximum energy potential of the materials in the system from known chemical reactions.
In a joint statement, Dr. K.V. Ramanujachary, Rowan University Meritorious Professor of Chemistry and Biochemistry, Dr. Amos Mugweru, Assistant Professor of Chemistry, and Dr. Peter Jansson P.E., Associate Professor of Engineering said, “In independent tests conducted over the past three months involving 10 solid fuels made by us from commercially-available chemicals, our team of engineering and chemistry professors, staff, and students at Rowan University has independently and consistently generated energy in excesses ranging from 1.2 times to 6.5 times the maximum theoretical heat available through known chemical reactions.”
Moreover, BLP scientists were able to regenerate the fuel by simply applying heat.
More info and pdf's on above link.
They left out an important detail - how much heat is needed to regenerate the fuel ???
More or equal to the amount produced and you have just a fancy way to produce thermal energy, and if less heat required then you have true overunity.....
mscoffman
There is a energy called Wigner Lattice Energy that gets released
upon heating of a metal, that is built up during a pre-processing
phase. This is what they may be seeing in the process involving
sealing a metal fuel into a canister. So, yes, they need to look at
the energy involved in the full fuel cycle before they claim anything.
I have yet to see any "smoking gun" experiments for the hydrino
after following blacklight for several years. But CF cold fusion
seems to be found where it is looked for, once it's parameters
are known.
:S:MarkSCoffman
Omega_0
I also suspect cold fusion in this case (if its not a hoax in first place).
I guess they are staying away from that word, it has a dirty image and TPTB panic when they hear it.
