New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
minde4000
Last Stefan post looked sort of something promising..
Ali could keep public here up to date on whats going on not thats he has to but.. time will tell I guess. He said he would share..  :)
Minde
hartiberlin
Ali said,
that he would take samples via his DSP from the input each 10 milliseconds
or so and then has 40 computations time for taking the next sample from the input.
In these 40 instructions ( computations ) he would charge up the other cap like an
"image" of the other cap and then he told something like a^2 + b^2 or (a+b)^2 or
something like this , I did not understood what he meant by it , maybe somehow the
shadowing of  charges inside the caps and thus maybe electrical induction
influence charge generation ??
the connection was pretty bad, so I did not fully got it, what he meant.
He said, he uses a DSP with ADC and DAC converters and maybe his DSP is also
producing the 50 Hz Waveform via an external Power DAC and the Supply Voltage for
the DAC is just using the multiplied input voltage ?
I really wonder, how he produces the 50 Hz waveform from the chopped phase input signals.
He said, with the ADC he can trigger the DSP on the zero point crossing, so he
knows, when the input goes through zero.
Maybe he uses this to generate a new 50 Hz signal based on the zero crossings ?
With DSP code you can do lots of things, so it seems this is pretty complicated all
and will depend mostly on the software.
But it would be good, if we would know the basic effect behind his "? charge-imaging-shadowing ?"
effect, so this could also be tried with simpler switching circuits, not just via a DSP only...
Regards, Stefan.
FatBird
Stefan,
Thank you for posting and sharing what you know about Ali's Unit.
Could you please ask him what value the 3 Caps are (voltage rating and how many microfarads).
Thank you very much sir,
robbie47
What really matters is the way Ali produces the extra energy.
This is the core of it all.
It would really help if Ali would explain first how he is doing that.
The next thing to know is what kind of switches he is using.
Are they FETs or Triacs?
