New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
forest
I'm wondering. Maybe there is a possibility to charge electrolytic capacitor without consuming current. Just do it much faster then relaxation time as explains Bearden ? What do you think ?
YeahRight
There is no chance in the entire universe that capacitors can be charged without consuming current.
Quote from: forest on October 15, 2009, 09:30:00 AM
MasterPlaster
jan.kolar
Quote from: winsonali on August 31, 2009, 01:24:29 PM
em devices:
i do understand that SMPS (switching mode power supplies DC converters) in computers, badly effect power factor thats why  the european union put a ban on chinese power supplies until and unless they are properly certified for PF close to 0.9 min. when a PF changes meter reading go faster because realpower = V * I /pf for example if voltages are 220 ad current is 1 amp the power is 220 watt when pf is 1 now if pf is 0.5
lets see what happens  real power = 220 *1 /0.5 = 440 watts so if pf is changed you will pay more not less and pf more then one is not possible
if PF is low power companies become in trouble coz then they have to transfer more current to meet the real power then apparent power so they put penalties if power factor is below 0.8
i am an ex proffessor from  an engineering university and have very clear vision of electronics and mechnical systems
220 volt coil in meter is parallel connected called activator magnet it can only make path for magnetic field so if there is no load it won't coz movement on disk even voltages are applied
current coil is called multiplier so disk only move when current flows so in this way it acts as power = V* I
what is siphon
if you want to get some fuel out of motor bike tank you put a pipe in it and suck it from other end then the fuel will start flowing to a lower destination but it will fly up in pipe for transition time this is called siphon i have develop this method in electronics and handling current in this way.
amazingly i got success my concepts are different from all other people working in this area
i have some other inventions as well but will show them after the successful trials of this one.
Ali
realpower = V * I/pf. I must say that this is not true. Correct formulas are following
apparent power = V * I
realpower = V * I * pf, where pf = cos(fi), fi is phase angle between current and voltage.
reactive power = V * I * sin(fi)
V and I are rms values of current and voltage.
I must agree with EMdevices that you get charged only for real power. This is how it function in slovak & czech republic and I think also in another countries. According to law PF must be in range <0.95;1>. This is particularly important for big electricity consumers. If their powerfactor is less then 0.95, they can be charged up to 50 million czech korunas which is almost 2 million euros! I think that similar law is established in Slovak republic because we lived many years in common state.
That throws bad light on winsonali and his "expert" knowledges.
teslaalset
Jan, can you explain the brighter lamp bulbs with power factor?
