New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
allcanadian
@jankolar
QuoteAli is only muddlying water nothing more. Maybe his device is ingenious but i dont believe on overunity. He has not answered the main question: Where this additional energy should be coming from? I dont accept his analogy with siphon because this phenomenon is very well understood by science, no energy gain here. If he would made plan of his device public then experienced members of this forum with apparatus needed could quickly confirm or refuse overunity effect.
You seem to be making an awful lot of assumptions considering you have no idea what Ali is doing? I believe Ali is here because he wants to share his progress with others so we all might learn in the process, right or wrong his effort is a noble one. Let's address your question---"Where this additional energy should be coming from?", The first mistake is assuming their is extra energy. If I have a car and I modify the engine to get 20mpg above factory specifications, have I gained energy? No, I have improved the efficiency and wasted less fuel, this is not a gain-- it is less losses and there is a difference. Let me put it to you this way, conventional domestic AC wastes almost 100% of the energy transferred--- what you consider as 100% efficiency is in fact closer to 2% efficiency because you have continuously discharged the source. Even a cave man knows better than this,lol, do you think a cave man would light a fire(create a potential difference) take some heat then throw water on it---then re-light the fire/pour water on it and repeat this cycle? I have a very good idea what Ali is doing as I have been building circuits along these lines for quite a while and he is correct with his siphon analogy. James Clerk Maxwell once said--- we can view the forces we measure in a mechanical sense and in this respect I mean to be taken literally. I think the reason you have no idea what Ali is doing is because you will not consider his perspective, to understand his thoughts on this matter.
AC
jan.kolar
Quote from: allcanadian on November 05, 2009, 09:55:42 AM
Laws of science are verified by long-term practical appliances. Where is this unknown huge bulk of energy many times more than we are using every day? Point to the equation in electrical theory that you think is wrong? Why this flaw has not manifested as some anomaly in laboratories all around the world? Transfer of electric energy from source to load is described by Poynting vector ExH. To make H there must be electric current flowing from source.
quarktoo
The "laws of science" are have so many exceptions it could better be named "the laws of oil company and central bankers profit."
The laws of science are a house of cards that are going to collapse when people figure out that acceleration converts mass into the atomic energy contained within the mass and that is how all free energy devices work.
I don't know if this device works or how, but I wish the inventor well and thank him for sharing his information openly. That is something that I can support and the type of person I would want to help.
winsonali
Hello all,
i was working and finalizing the independent and self running unit where you need not to have a dimmer
this is a new unit please do not mix this with genie
i have developed a model which can produce electric power without inter crossing the magnetic field
in a generator motor most of the power consumed is due to the inter crossing  magnetic fields if you  require more current means more power full magnetic field and this means more mechanical energy required to inter cross the polarities to generate current
i have successfully achieved the method of  generating electric power without inter crossing the magnetic fields my method is in initial stage i have just produced 1volt 500 milliamps with very small size of this new device once  i will produce 30 to 40 volts that will be feeded in genie to produce 240 volts through that device
My question and help needed is
to produce electric power i am using non magnetizeable material in a magnetic environment
if any one can send some links to magnetic properties of materials (like alloys of aluminium , zinc and brass etc) so i can make use of some more better material for my experiments
please send me links, if you have knowledge of any device of this type that produce electricity through a magnet without inter crossing the magnetic fields
hartiberlin
Hi Ali,
sounds great.
Is this already 0.5 Watts of power or does the voltage drop,
if you draw 500 milliamps of current ?
Exactly for what parameters of the materials are you looking for ?
For the conductivity or permeability or what exactly ?
Many thanks.
