New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
hello ALL,
this is the most perfect parallel path magnetic arrangement any motor designed on this concept will be free of lenz force. this cannot work as generator
Nihilanth
It can not work as a generator, but what can it work as & what would be the benefits?
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
aaron5120
Quote from: winsonali on December 19, 2009, 01:54:56 AM
hello ALL,
Hi Winsonali,
This setup has already been patented by Jack Hildenbrand, who passed away this year soon after getting his patent granted( it was in March).
His patent number is US7453341 for your reference.
The design is almost the same. Jack had been sharing his invention here for 3 years. You may find his thread in the Magnet motor section. I was trying to replicate the Hildenbrand valve, but some technical issues hindered the advancement so far. I think your invention is better. And I am currently making the core for the Flynn Parralell path generator. Not a Lenzless gen though.
Thanks for your contribution anyway, Ali.
winsonali
aaron
the patent is 1959 i have just adjusted the core
the only techniques is calculating the flux path and resistance to flux path due to air gap if you are capable to balance in between them then you do this other wise no chance
the gauss of permanent magnet will effect the current consumption of your coil
you need proper switching to handle the flux path
this can only be used as an efficient  motor or heavy duty non clamp able lifters where you turn of the magnetic field to release weight
Charles Flynn generator will not work as they are not changing the field direction after few second the core will be energized in one direction and you will not get any output.
winsonali
aaron here is the schematic diagram of magnetic generator  this can handle power upto 3000VA
the schematic include has a display of 2 * 20  to display to show frequecny ,output voltage, current and RPM
