New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
ramset
winsonali
This world needs a few changes,And definitely more people like you!!
  Chet
Thanks Grandma
winsonali
i was posting some information on another thread and they are usefull for many people so i am repeating them over here as well
Now coming to the technical part of the post the essence of the post is
1) DC cannot demagnetize core very easily.
2) DC when come across with closed loops it retain the field for more time then in open loop.
3) either of loops input or output both make same effect on core.
it is very helpful for other people reading these posts.
when i jump in this post i put forward the same thing that until and unless the power generation unit is reversing its polarities you cannot produce electricity.
in making my genie working i have not used any coils or transformers.
the sine wave we are using is not by choice, is by early designs there is no harmful effect on electrical devices operating under square wave reversing alternative current, if they are operating through DC i mean almost 90% device use DC conversion to operate for example computers televisions etc etc. even DC motors.
now if you see the picture i am putting you will under stand  what is effective area under curve is same as effective area under square wave.
i have developed inverter based on this switching techniques and i have 2 hours extra backup in my system at 1000 VA.
i have gone through with various patents involving PM in transformers and try to understand why and where they have conceptual differences.
flynn charles MEG will not work as  a generator but works as a parallel path magnet field.
i will be posting my next video early next week, video for the self running unit.
winsonali
if any one need the transformer calculation software just send me email i will send you zip file
gotoluc
Hi Ali,
thanks for sharing this technique :)
Would one not use a ferrite core transformer considering the frequency is basically 42KHz?
The only difference I see is pauses between and polarity shifts.
Good idea ;)
Luc
winsonali
gotoluc
the ferrite core works on the principles as per faraday laws
v = N d B/dt
means voltage is directly proportional to rate of change of flux 42 KHz means in other words/ mechanical analogy
a generator working on 2520000 RPM
now in this case the benefit is you need less number of turns , higher current, less spikes low value of capacitor to provide dc conversion notch filing gaps of wave form. The ferrite core can lose its value of B very quickly or its BH curve is very steep and vertical. so you cannot get the fly wheel effect
for example mechanical analogy
if you use a 250 gram wheel on a motor top you will get low momentum but if you use 2 kg wheel you will get high momentum and that will store more kinetic energy then light weight one.
some times it is desired to use light weight wheel and some times it is required to use heavy weight wheel it depends on requirement.
now 99% percent books will say that the CRGO( cold roll grain oriented ) core is not siutable for high frequency such as 20KHz they are siutable for 50 hz to 100 hz or some times 400HZ thats all
here this is misunderstanding and this is the biggest advantage when they refer 50 to 400 hZ means core cannot return to neutral position faster then this frequency so any attempt to get it back or reversing the polarity faster then the prescribed values will heat the core and do nothing but loses.
Now understand what we are doing we switch the magnetic field in one direction and then with in mill seconds turn it off, the flux retains there the output will get the same effect but you have turned off your supply now before the core starts going back you pushed it again so you are getting the fly wheel effect but the out put is same and with each and every switching you will get BEMF going into battery again.
in ferrite core you do switch the frequency in reverse direction every time or if you have single direction switching you tend to reverse the magnetic flux to min during off period so you didn't get any advantage.
SMPS were designed to reduce the size of supply and they are complex circuits and serving there purpose very well otherwise you can imagine a computer power supply can be bigger then the computer itself. due to high current requirement.
the above technique will increase the time of your inverter twice and very use full for solar panel or windmills.
if you need one unit i can send you the normal weight of a UPS for a 1000VA is 12KG.
the technique of BEMF collection involve smart switching and turns off the main supply during BEMF collection.
