New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
aaron5120
Quote from: winsonali on December 19, 2009, 05:17:46 AM
aaron here is the schematic diagram of magnetic generator  this can handle power upto 3000VA
the schematic include has a display of 2 * 20  to display to show frequecny ,output voltage, current and RPM
Hello Winsonali,
Many thanks for this great controller circuit. I am taking a first look at the schematics, and have a few questions for you, sorry to keep bothering you with so many questions, please bear with me!  ;)
1) There is a battery connection in the circuit. May I ask what this battery is for? And what Voltage and AH (in case it is a rechargeable one)does it has?
2) There are 10 coils and 5 magnets, Can you please elaborate how is the way the generator coils are to be connected between them( in parallel or in series, or individually) and which is opto for controlling the switching? Does it need to be located in the rotor's shaft?
3) I see 2 channels L and H. Are they outputs of the controller?
4) The neutral is not the ground in the circuit. So where does this neutral come from?
5) Does the AC in connect to the coils input?
6) And the AC out connect to the socket? Then 3000VA of power will be in 220VAC?
7) Where to select the different display functions of the IC AT89C52 ?
08) The outer magnet collar of your magnet setup----you first shield the inner magnet with a Mumetal collar, then did you custom make the outer magnet collar to host the shielded magnet? What is the specs or important parameters to look for for the outer magnet collar?
9) For 10 coils of 50VA each of pick-up power, Is it all-right to use AWG 25 magnet wire to wrap 550 turns with an air core of say 20mm diameter for each pick-up coil?
10) I suppose the magnet rotor is going to be moved by an DC motor, is that right? So how can I adjust the RPM of the rotor speed?
11) What is G1 terminal for?
Aaron
smithandwes
just found this thread..anyone building or built one..where do i get the schematic/build info?
winsonali
aaron
i am very happy that you are serious in my generator i will send you a detailed reply on your email address
just for now
you collect the voltages generated from all coils in one capacitor bank after converting to DC then you can use them.
AT 89c52 i have programmed it  so it can sense the AC in and ac OUT FREQUENCY  and many more things switching input out load selection and each stage is separated by opto coupler.
thank you for your information regarding US7453341 patent.
i think both Flynn and Hildebrand use the patent information dated 1959 and developed there technologies on them
the motor based on PM switching technology will be lens free and the generator i have developed is also lens free combining them you can get extra energy.
may be you can think ... why i am not working on this any more? ....
coz the new technology i have developed is far more superior then this and requires no moving parts
just waiting for right circumstances to display the new technology.
i will send you programmed controller to complete the circiut
winsonali
aaron
the DC input in circiut is coming from this picture
it will be monitored by software and Duty cycle will be changed to adjust the load and voltage
aaron i have a vision world needs a new concept we need to develop devices that can handle magnetic flux just like we have capacitor, inductors, diodes , transistors to handle electric current we need to develop the devices to handle the flux this will be new concept and will perform better then what we have now
i will develop first magneto-cell, a cell that will generate electric power just like a magnet generate flux.
vision is the first step towards destination.
Nihilanth
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
