I see an economic diasater coming...
Started by the_big_m_in_ok, September 03, 2009, 01:05:30 AM
Do you think the American economy will ever improve?
Yes, definitely
Possibly, in the long run
No, it will worsen
Undecided
http://en.wikipedia.org/wiki/The_New_Industrial_State 1967
Galbraith argues that the "industrial system" - by which he means (in general terms) the companies which control around two-thirds of output in key sectors of the economy - are controlled in practice by a technostructure rather than shareholders; he claims that the technostructure does not act to maximise profit (as that involves the risk of failure) but principally to maintain the organisation and, as a secondary aim, to ensure its further expansion.
Galbraith also asserts that the traditional notions of risk most closely associated with small enterprise become less relevant to large industrial enterprises and conglomerates
Risk is diminished, Galbraith says, by advantages large enterprises have in securing longer-term supplier and labor contracts, and by the use of financial instruments such as commodity futures to mitigatevolatility in raw materials prices. Political influence of large industrial concerns in governmental economic and labor policy is cited as another factor that tends to create the stable market conditions that are necessary for corporations' long-term planning of production.
http://en.wikipedia.org/wiki/The_Economics_of_Innocent_Fraud 2004
5. The illusion that shareholders, stockholders, investors, boards of directors—even owners—are relevant to the large corporate entities that dominate the economy. In fact, claims Galbraith, it is management (corporate bureaucracy) that runs them (pp. 28–31).
                                   " Apparatschiks"
8. The illusion that the Federal Reserve, by raising or lowering interest rates, has any effect whatsoever on spurring growth or preventing inflation. This Galbraith calls 'our most prestigious form of fraud, our most elegant escape from reality' (p. 43). According to him, 'only in innocence does it [the Fed] control general consumer and business spending' (p. 47).
In three concluding chapters he makes a case for impartial government oversight of corporate behavior; returns to his theme of corporate dominance in the affairs of the state,
particularly in the military and defense, for its own enrichment; and claims that additional tax relief for corporations serves no public good.
He ends by drawing an analogy between the failure to redress social hardship through sound economic policy and the dominance of war-making in our economic life. He calls war 'the decisive human failure' (p. 62).
                           the_big_m_in_ok(Lee) ,
I please you to correct the September 03,2009 theme from
"I see an economic diasater coming ...." with the common sensual writing
"I see an economic desaster coming .... " !
                                                   Will you ?
Now back to "Nobody ..." and showing the classical analytical tools of future
market price trends/tendencies and there is not a hyper-processor need:
                                     Paretto scoped Analysis
above -  Max-to-Min  -orientation V , the base above and the peak down
  up      -  Min-to-Max  -orientation ^ base down and the peak up
                          Piramids/Triangle/(Co-/Sinus-)Curve
                    ( also related the Gaussian Bell and the Galton pad)
                                           [(e)statistics]
                                theoretical ideal example:
Maximum          X                     X                in-           (+AC)       up/down movement
Optimum        X    X               X    X
Medium      X- - - - -X- - - - X- - - -  X- - - -                neutral (DC)  flat(ion) curve line
Pessimum                  X   X               X   X
Minimum                       X                    X       de-        (-AC)          up/down movement
                      action   ( il/legal free/manipulated)/
                    reaction ( il/legal free/manipulated )
        market ware/currency price cycle/conjunktur wave current
                                      observation
                included Elliott/Kontradjef (e)motion cycle
                        movement is not linear,it is progressiv -
       under dynamic( accelerating + ++  +++/decelerating - -- ---) condition
                               cause "gravity" influenced:
   this empirical observation known as subject from the George King's Rule
                Frequency(Distance/Amplitude) and Voltage(velocity)        Modulation/Modulator:
                             2-/3-/4-D     geometrical bodies like humans
                                                 Phänomene
Das Massenträgheitsmoment beschreibt das kapazitive Verhalten eines rotierenden Körpers. Dreht sich dieser um eine Hauptachse, nimmt der Drehimpuls linear mit der Winkelgeschwindigkeit zuL = J ω,mtDas Verhältnis zwischen Drehimpulszuwachs und Winkelgeschwindigkeitsänderung entspricht direkt dem Massenträgheitsmoment. Lässt man nun über eine bestimmte Zeit ein Drehmoment auf verschiedene zylinderförmige Schwungräder einwirken, führt man also den Schwungrädern eine wohl definierte Menge Drehimpuls zu, stellt man fest, dass die Winkelgeschwindigkeit um so weniger ansteigt, je schwerer das Schwungrad und je grösser der Durchmesser ist. Durch die Zufuhr einer bestimmten Menge Drehimpuls steigt die Winkelgeschwindigkeit umgekehrt proportional zur Masse und umgekehrt proportional zum Quadrat des Radius der Schwungräder.
Pirouette,en
   organized human gravity and "mass of inertia(Massetraegheit(smoment)":
                                          manipulation
          this is "open source" knowledge given by social economy books known
                      as subject inside the"Golden Bank Rule"
"hedging/levering" gains by selling credits,only caped/warranted with 10%
  real capital ( bank + life assurance+investment funds thesaured,T-bonds: Basel I,II,III,..: Min-Reserve for the " society commodity future" called credit/hypothec ))
           but be paid back with 100% credit/hypothec virtual sum:
      this alone gives a 1000% brutto margin for the finance/estate sector
      and the second gain the paying from -not capital,but virtual contract sum
                                       based tax-rate:
         7% contract sum taxation means 70% capital tax rate -per annum/per year !
                           Annuitaeten-darlehen( to lease,lean)
                       up to the so called F.E.D. T(reasury)Zero-bonds
                                this named in german:
         virtuelle Geldschoepfung ohne reale Geld/Wert-Schoepfung:
                                  " magical/fantasial" money creation
                       A very commod future to all and everywhere !
            Mr.Alan Greenspan, what is your competence: Magic  :-\  ?
                                                         the vulgar paper  Magister you have,I know.
                                        the common future
                                             Dubio ? Doubts ?
               Reread in -the links - ( with paper and pencil beside,copy)
                                                the reo=the indices
                          pro ( not guilty)/contra(guilty) Indizien/Indikationprocess
                                    for the common and your forecast
                       predicted by liberal heart-/barrier-breaker,Futurists
I am only in a little server-function with some hobbies
A sinical S(o)unday(cristian world) and happy work elsewhere
        OCWdL
SeaMonkey
lancaIV,
Your recent series of postings are right on the
mark in demonstrating the corrupt nature of
the United States of America and how the
Agenda presently being enforced in the U.S.A.
and the World are bringing the New Order into
its final stages.  What is soon to come is going
to be very UGLY.  What we're seeing now in the
rampant corruption and culling of the population
is but an unpleasant foretaste.
SeaMomkey,
it is not a "Anti-U.S.-Amerika"-statement !
Do we not find in each U.N.O.-nation( included NGOs) member a same/similar behaviour ?
China ( claiming worldwide "De-Amerikanization" !) :
sino-/ china-nization better ? not the same ?
Russia/Rossia ?
India(Pakistan,Bangladesh): greatest "humans powered" democracy  ::)
        on earth ?
Germany,GB,France, .... E.U.,OAS(where there the Presidents/PMs/opposition leaders received their education ?).........G7/G8/G20
All of them has this shown and linked literature as teaching/coaching/educating help ,members from the social economy "hall of fame":
Nobel-Prize,Harvard-University degree,estate consultance.
Well doted ! Or not ? Well honorred ! Or not ? Well praised ! Or not ?
what did they with all this compact wisdom and knowledge ?
Why does not the "normal" citizen,or let me say the majority,interest for this theme denominated "social economy" ?
The Paretto-Coordination show 2D dimensional each individual human /them,the Folk /us the 3/4D society EEG/EKG-diagram, "was-is-will be" patient wealth/health history act comparing dia(g)nosis/prediction/recommendation.,
in economy algebraic language the 3/4D geometrical function process,
which you will find in the emergency room from clinics/ambulance/hospital as that tool software/function principle :
                                               Echogra-ph/-m (Doppler-Phenomen),
                                               Electrocardiogra-ph/-m,
                                               Electroencephalogra-ph/-m
                                               sys-/diastolic pulse measuring
                                               blood pressure measuring
The german intonation about what I am writing,from Kraftwerk,album 1-19
http://www.youtube.com/watch?v=BGD7j5SNowA&list=PL8FBC57BD4EAF2CF8
  Speed: "schnell,schnell,schneller,noch..."velocity/
                drugs(endorphin/adrenalin/.... for empty humans body synthesized
               for "(Struntz),flask empty" people
               ( citating,translated: Trappatoni ,FC Bayern Munich :
           Angel dust/cristal myth: with up to no limit ekstase:Epilepsy/Canibalism)
                                         Euphorien and Hysterien
                          Using for the good,using for the bad,(a-)b(i)used ?
                   2nd (war survival supplement test) project : Gulfwar II-Syndrom
                   1rd  (war survival supplement test)             : Manhattan project
Reading the supermarket ware/sortiment position organization show us our different kind of deficiencies observation :
old (eye,ear/body-/head-ached people/analphabets: expensive ware/goods on their "satisfying fast buy " by credit card (Factor 10X + expensive/cheap good relation quotient)
cass area: waiting- do you take me,too( one,two)-products( high margin), Kids(bored :sweeties,puppies,matchbox like cars,et cetera...)
                  for Madames high-society magazines/ geral: tobacco
this above written and printed for economy school pupils/students in Germany
8.,9.,10.class (average age 15/16 years old)  as knowledge from Psycho-/Neurolingual-observation and development of "more money spending "-barrier
power tools.
Industrial products with industrial produced "low temporal durability",malfunctions included for reclamation to pay for service/expensive reparation parts(no warranted) and clients adress comerce !
         Fair is our world only when the unfair individual goes far-ly to Hades !
   take( ida/volta ticket or only ida ?) 8) me/you/he-she-it/... to the other side !
  Lieber natuerliche Gluecksmomente als chemischer Ersatz ueber  "Glueckperlen" !
SeaMonkey
Aye, 'tis very true.
The Protocols have affected all of the
Nations on Planet Earth.
Thankfully, not all of those who think of
themselves as ELITE are in agreement about
how and when the New Order will be finalized.
Watch in amazement in coming years as the
"good guys" are neutralized and eliminated.
The common people will suffer worst as has
always been the case.
