I see an economic diasater coming...
Started by the_big_m_in_ok, September 03, 2009, 01:05:30 AM
Do you think the American economy will ever improve?
Yes, definitely
Possibly, in the long run
No, it will worsen
Undecided
triffid
big m,I got to see those inverter plans because I used a different computer.I think a mechanical inverter is novel.I once made an interrupter which used a flashlight battery for power.I sent the interrupted current through a step up transformer and shocked myself several times that day.I guess the current is not squarewaved but close to it and messy.Your inverter reminded me of that device I made a long time ago.I used air as the medium but adding a capacitor to the points would have cleaned up the waveform.And less sparking would result.I used junk to make it so it didn't last too long.triffid
the_big_m_in_ok
Quote from: triffid on May 21, 2010, 11:48:59 AM
Yeah, I borrow computers and they have .PDF compliers on the hard drive as a public service to free customers.  I download lots of wiring diagrams that way.
Here's hartiberlin's rendering:
http://overunity.com/index.php?topic=3111.0  ,  Reply #5
This should last until the relay points wear out.  However, he needs to wire the relay contacts through the coil so the current in the coil energizes it, thus breaking the circuit until the spring reconnects the contacts to complete the circuit again as a chattering 'square wave' response with a frequency of, say, 15-25 Hz.
I'll try to remember that about the capacitor.  I don't have a 'scope, so I'll have to take your word for it.  A diode between the relay and BEMF coil would take some voltage off the relay contacts.  They'd last longer, especially at relatively high voltage on the batterie(s).
--Lee
triffid
This guy made a boat out of cardboard .His method could be used to make a cardboard palace if one wanted it.So I hope to make at least one solar panel out of cardboard using some of these methods.triffid
http://www.instructables.com/id/How-to-build-a-cardboard-kayak-for-less-than-40/
the_big_m_in_ok
Quote from: triffid on May 21, 2010, 04:56:51 PM
Be careful for rain, triffid.  I never hears of water repellent cardboard.
Wait, maybe I spoke too soon?
http://www.pat2pdf.org/patents/pat6794016.pdf
It might work after all, as long as way too much water doesn't flood your solar panel.
--Lee
