I see an economic diasater coming...
Started by the_big_m_in_ok, September 03, 2009, 01:05:30 AM
Do you think the American economy will ever improve?
Yes, definitely
Possibly, in the long run
No, it will worsen
Undecided
triffid
http://snardfarker.ning.com/profile/bigjohnlipscomb
i watched big jhns dvds on secret gardens and how to make a water filter.
it gave me hope that people could survive a collapse. triffid
http://snardfarker.ning.com/forum/categories/survivalism-and-gardening/listForCategory
triffid
want to build an underground bunker?
As far as burying yourself in the ground goes, it seems to me that it would be bad for morale in the long run, but if you are interested in how to dig a big hole safely, look up the digging techniques used to dig basements for houses. To summarize, plan for a ramp about 3-4 times longer than the hole is deep, or use a track hoe and go from one end to the other. Just bear in mind the method that you intend to use to get the container/structure down into the hole when you decide how to do it. What I would consider the ideal setup for concealability is a metalic container buried under 18-36 inches of earth near a stream that you could wing dam for power, metalic cased well sunk inside the container with the casing welded to the container, and shielded wires running from the hydro unit to the container, shield grounded to the container and in the stream. Probably still be radar detectable, but it would look a lot smaller than it actually was. A round tank will give a lot smaller radar return than a square container. If you stay in one place for long enough, you will be found. If you stay on the move, you may be found, but you have a chance at doing the finding, and then dealing with the situation on your own terms. Either way, if you are set on a worst case, it might be good to be ready to die, because any way you go, it is a certainty sooner or later. Personally, I do not think that the situation is hopeless yet, so I am putting the bulk of my energy right now into salvaging it, and only a little bit into preparing for it's collapse.
triffid
I would consider carrying a tent with me.Backpack with tent.
triffid
Just some guy ranting and raving but I share his views.It could be me in this video.     http://snardfarker.ning.com/video/joblesshouselessrecovery-lets
triffid
triffid
