Correction...TPU Steven Marks Earth's MAGNETIC FIELD....oops.
Started by leeroyjenkinsii, September 03, 2009, 07:25:24 AM
darkspeed
dont block it, let the pulse moving through the wire deplete the field then the earths field will reclaim the space the pulse moved through.
http://www.overunity.com/index.php?topic=8003.msg199963#new
but i could be wrong, or maybe not ;)
leeroyjenkinsii
I'm not sure about your scenario.  I'm specifically talking about redirecting or blocking the magnetic field of the permanent magnet away from a collector\coil\part of a transformer then unblocking\unredirecting so it essential will pusle to the coil\collector\transformer.  Basically it would be like a the receiver portion of a transformer but using a permanent magnet that can be turned on and off--not shifting polarity.  This should still work but I don't know if you can easily redirect/block the permanent magnet.
Anyone know if this is possible or how hard it would be(how great the electrical cost would be)?
leeroyjenkinsii
Ok.  According to the Wikipedia article below a Hemholtz coil can be used to cancel out a static magnetic field.  I don't know about you guys but looking at SM's TPUs he could have very well been using these to create the pulsing affect by essentially making a permanent magnet into a pulsing dc electrical generator.  He did mention it was working at 6000hz.  Maybe he was blocking the permanent magnetic field with Hemholtz coils at 6000hz creating pulsed dc in the primary collector coil.  What do you guys think?
http://en.wikipedia.org/wiki/Electromagnetic_shielding
leeroyjenkinsii
I'm probably way off base with these ideas.  I really lack the technical skill to attempt to set it up anyway.  Let me know if anyone has the materials and can try this.  Also, let me know if it would just take too much power to block the permanent magnetic field using hemholtz coils.  Maybe part of it could be blocked with permanent shielding.  I don't know.  Possibly just a bad idea all around.
