Bedini pulse charger buster
Started by Silvije, September 04, 2009, 11:43:33 AM
Which buster schematic just might work (produce "free energy") in your opinion?
1 - 2 bifilar coils
2 - 1 trifilar coil
3 - 2 bifilar coils
4 - none of them
Silvije
Quote from: guruji on September 11, 2009, 05:51:46 AM
Hi Silvije I did not want to offend you about the time comment but did you build that circuit?so that I will replicate as I build others of bedini devices.
Thanks for sharing after all.
Guruji I believe I have answered you this question already but I know it is hard to read through lot of nothing left here by characters like gadgetmall.
Question for moderators: is it possible to delete some posts or/and to ban somebody from posting on some topic if the person is writing off-topic stuff and insulting others?
gadgetmall
You Started it With your sarcastic about My Patents Man.And No Everyone has a say here and If i offended your Intelligence then Sorry Just a Space in time and you caught me in a bad mood son . Sorry .At the Very Least I can show My Interest to help others even if you don't see i was trying to help because of My success in self charging Devices I am Now Offering you a Truce and a test of Integrity .I am Going to Build this Dream Circuit and offer to compare it with your Results If you Dare ? .using Quad Coils with that one extra Bi Coil  and Pots In place of the resistors to Compensate however Groundloops Cleanup Is a Nice Clean render of the Idea In 12 volt form and i  Will attempt to build it in a rotor design . What will it do remains to be seen. We will See. Could also Build this without a rotor If it Does trigger Properly I do Think By placing the coils close together . It could also cancel each other out if the phase is exact and without capacitors the out put will have hardly any affect other than maybe self conditioning  . a Bedini needs caps for Bemf Amps to amount to anything . As you can see in the piggyback Crappy video here http://www.youtube.com/watch?v=JRnYQvYEwkM you so call it i light a 130 incandescent  lamp from One of My Bedinies running 12 volts at a Fraction of input current less than 50 Ma . . This is only because of the caps on the output circuit.  , As far My proven Circuit Located here http://www.overunity.com/index.php?action=dlattach;topic=6519.0;attach=29140 The return path is isolated unlike here http://www.overunity.com/index.php?action=dlattach;topic=6519.0;attach=30403 which uses only one battery and is proven to work by many even though you yourself have not tried it or it failed do to another factor explained . And Yes you can feed the output from a Standard Bedini Back spike circuit directly in the run battery . If i was to put Two identical circuits on one rotor out of phase i would expect more power required to run the extra coil . The Perk here is to get the Minimum amount of trigger circuitry to the absolute minimum below the output level . I have done it and its not that hard to spin a magnet at less than 1 milliamp . Also remember you can capture the remaining generator energy with more coils . the composition of the Core Would negate Drag down and as you see excess energy is produced in excess of the input . after all the spin is free and is only a trigger component for a bedini . Al this Is History stuff that is proven. The Key  is How Little and how fast  does it take to trigger induction to obtain  current excess from magnet generated coil output plus series Bemf from the Bedini electromagnet/Back generated Capture . To achieve this is a matter of how good you wind your coil and its resistance . Your going to need over 60 ohms worth of good copper wire  and more to achieve this .
Silvije
Quote from: gadgetmall on September 11, 2009, 10:21:13 AM
apology accepted,
I am sorry if I hurt your feelings too.
You did not realy explained to me how that self runner circuit of your works,
I believe I still do not understand it. I see how the current loop should close but there is a problem. Isn't a diode D2 really shorting C1? How can that work?
Silvije (that's my real name, not nickname)
Silvije
here is another idea, with two coil windings...
both have a triger coil and one have main and other have recharging coil
edit: I have re-uploaded circuit image bacause I made a little mistake with diode orientation...
Silvije
somehow this first schematic seem to have most sence to me,
and we could add third coil which could be also used for recharging or
wound trifilar both coils and use extra windings for recharging
