Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
X00013
hello, i give you credit for going with big diameter and weak mags. balance the wheel and show it, if it takes longer than 10 minutes, compress vid, use vegas pro
mr_bojangles
i dont understand what time restrictions have to do with anything,
a balanced lever would conclusively show a gain, and if you chose not to use a balanced lever because it didn't work, then it isn't a gain
that way you can show there is basically no input and whatever output you got could be considered gain
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
WattBuilder
Quote from: X00013 on January 24, 2010, 12:53:24 AM
X00013,
They are not weak magnets and compressing the video will not shorten the time. It will decrease the video quality.
Quote from: mr_bojangles on January 24, 2010, 03:50:56 AM
i dont understand what time restrictions have to do with anything, a balanced lever would conclusively show a gain, and if you chose not to use a balanced lever because it didn't work, then it isn't a gain
Bojangles,
I replied this to you. Please take the time to read. When you become a builder and place your videos on YouTube you will notice YouTube does not allow a recording time of over 10 minutes per video.
Quote from: WattBuilder on January 24, 2010, 12:17:08 AM
The reason why I made it slightly top heavy is because of the 10min time limit on YouTube videos. I don’t have all day waiting for the lever to stop floating around (weight less) every time I touch it or wait for it to pick a side and slowly rest before I can take a measurement.
This is a clear as I can reply. If you still don’t get it. Just read it again or sleep on it. You will eventually see what I’m talking about.
Howard
Bojangles,
I’m not even worried about the slight imperfection of the weight. For the reasons I have pointed out to you. I’m working on figuring out the best way to measure the Output. If I don’t get a positive gain IN vs OUT I still have the YU Effect to fall back on.
If you still have concerns. Be patience for my next video.
Howard
Video: The Yu Effect â€" Kinetic energy gain from magnets
http://www.youtube.com/watch?v=iBtl0OTSccs
happyfunball
nightlife
I am sorry to say that this design does not produce any free energy. The calculations are all wrong. Lift a rock up with your meter and then drop the rock on it. You will find the same results if not better.
Another way would be to do away with the magnets and drop the arm from the 11:59 position and take the reading. I bet you get the same reading if not better.
You will never produce enough energy to take the arm back to the starting point and or past. At least not with the design you are now showing.
  I am not trying to burst your bubble but I do suggest that you think about it more before making such false claims.
