Prof. Tutor shows Zero Point energy extraction into mechanical rotation
Started by hartiberlin, September 22, 2009, 06:58:10 PM
exnihiloest
Quote from: Xaero_Vincent on September 24, 2009, 05:06:30 PM
The rotor must be placed inside a high-vacuum dielectric to stop the influence of ion thrusts. There and only then will the rotor allegedly operate with a COP greater than 1.
It's right. But there is a much simpler way to stop the ion thrust: by placing a large plastic sheet between the rotor and the HV electrode.
Turtur is surely intelligent enough to know that. If he does not configure his experiment in such a way, we can guess the reason is either he tried and the experiment failed, or he did not even try because he prefers to believe instead of knowing.
niki
Kator01
Hi Stefan and all here :
why does the overunity prize does not go to Prof. Turtur ?
He has definitly proof of 50 time more energy-returned from the vacuum-field than invested and this was performed in a high-vacuum-chamber.
Kator01
DrZoidberg
lol, Prof. Tutor lives close to my home city. Maybe I should go to his university and ask him about his research.
fritz
[ author=onthecuttingedge2005 link=topic=8084.msg204116#msg204116 date=1255117710]
To get some perspective on how big a farad is, think about this:
A standard alkaline AA battery holds about 2.8 amp-hours.
That means that a AA battery can produce 2.8 amps for an hour at 1.5 volts (about 4.2 watt-hours -- a AA battery can light a 4-watt bulb for a little more than an hour).
Let's call it 1 volt to make the math easier. To store one AA battery's energy in a capacitor, you would need 3,600 * 2.8 = 10,080 farads to hold it, because an amp-hour is 3,600 amp-seconds.
it is impractical to use Capacitors, Superconductors are the next step to storing potential.
[/quote]
This comparison is only valid for storing energy at certain voltage.
So an AA Battery holds 4Wh
You would need a 1F cap charged with 14.4 kV to do the same...
