The Electric Field: Testatika, Lifter, Piezo, Diode, Crystal battery
Started by PaulLowrance, September 30, 2009, 11:42:20 AM
PaulLowrance
Bruce DePalma is the inventor of the N-machine. To me, the N-machine seems to be one of the legit "free energy" machines, but everyone stays clear of it. I don't have money to build one, but a lot of people at this forum do. Sounds like a good idea.
Piezos and diodes have been tested extensively. It's not due to fluctuations in air pressure or Sun activity or temperature or mesons or gamma radiation or beta particles or alpha particles. I don't know what causes it, but it's still a mystery. Besides, fluctuations in air pressure, humidity, etc. over time produce AC in an unshielded piezo, not DC. One long term test showed the piezo producing DC current for ~ a month, and kept doing so, but the experiment was terminated to free up time for another experiment.
People should not take my word for it. Take a $2 Radio Shack piezo element, part number 273-073, a low leakage capacitor (~ 1 uF), place it inside metal shielding (or a Faraday cage if you have one) in a quite room, let the piezo charge the capacitor for about 10 minutes, then measure the voltage on the capacitor. Your voltage meter should have no less than 10 Mohm input resistance! At 10 Mohm, the meter will drain the capacitor by 39% every 5 seconds. So really you should have a voltage meter with at least 100 Mohm input resistance.
Give it try. Anyone will see that no matter how much they shield the piezo against anything you want to shield against, it will produce the DC voltage. Contact me for details.
Then there's the lifter that accelerates in even a high vacuum of only 1.72E-6 torr. The mystery is that conventional physics cannot explain these things. I've had EE's & physicists replicate my diode claims, and a EE tested the piezo. It's still a mystery.
Paul
gravityblock
Maybe there is a link between all these devices.  I am almost totally convinced the homopolar generator produces a static electric field when the disc and external circuit rotate together.
Since it appears nature is producing a voltage and current in the devices you have mentioned with an electric field, then I see no reason why we can't do it also in the homopolar generator without using relative motion between the disc and external circuit.
I find it fascinating that a normal meter will drain the current so fast after the capacitor is charged with the piezo when it's shielded.  Does this suggest there is a low resistance in the system due to the shielding, which the low resistance could be another possible link to the homopolar generator?  Could the shielding lower the resistance of the system to a level where this unknown energy source has the potential to charge the capacitor?  The other possible link is both are producing a constant DC.
I guess we need to find the similarities between these devices and what they have in common to each other so we can exploit this phenomenon on demand and on a large scale.  I believe this is the purpose of this thread and I think you are on to something here.
GB
PaulLowrance
Someone just sent me a great email reminding me of work of Thomas Townsend Brown's on his discovery of the Petrovoltaic / Petroelectric effect,
http://globalfreeenergy.info/2009/10/02/the-petroelectric-effect/
IMO this field of science is what will bring global free energy, research from people such as Marcus Reid, and it's very close. I have ~ 2 years of extensive diode measurements taking all precautions, even going inside a cave to take measurements, replicated by EE's & physicists, and now the piezo is found to do the same thing.
So this is already proven, and anyone right now can replicate it to see real "free energy." A $2 Radio Shack piezo element, 273-073. A EE discovered this, and I confirmed it. The piezo's are shielded against RF energy, and sound & vibrations. It's real!
It is now important that people do different experiments so we can find any correlations to see what's causing it, to improve the designs to produce more power. The Edisons of the modern world. Edison experimented with hundreds of different light bulb filaments. The research is now at the place where this trial & error will help the most.
The myterious ~ 10 pA constant needs to be understand. Maybe the crystal batteries such as Marcus Reid is composed of countless individual units that each is comparable to a single piezo or electret, and when combined will produce far above 10 pA. The piezos initial current can be in the micro amps, but when the piezo was loaded for several weeks the current slowly dropped to a relatively stable current of ~ 10 pA DC. This ~ 10 pA is seen in countless diode experiments using dozens of different meters, different measuring techniques, different environments. There seems to be something special about 10 pA.
Paul
PaulLowrance
BTW, to do the above experiments one needs a volt meter with ultra high input resistance with at least 10 Gohm. An great inexpensive hand held DMM is the AM-240 (AM240), $40. Contact me for details & help,
http://globalfreeenergy.info/contact-me/
Some people want to be anonymous (a smart thing!) so you can email me with anonymous yahoo or gmail account @ your local library or star bucks if you want.  ;D
kamax
Have you a link with the diode producing 0.35 V ? I'm very curious of this.
