Thanks to ALL for your help!!
am i missing something obvious?
Started by shipto, October 02, 2009, 05:29:32 PM
1) use energy to create a water vortex in the tank
2) insert air filled object at bottom of vortex
3) extract as much energy back from water vortex
4) extract energy from air filled object moving up
5) compare input energy to output energy
If it works you would have done some very cool science, if it doesn't work you still would have done something not a single physics professor has thought of.
jadaro2600
using an electrode shaped like a ring at the bottom of the tank will create a vortex motion as the bubbles of the gas rise; the column creates upward  motion and in the center a vortex will eventually form.
Majority gas production should be at the lowest point, ..the height of the second electrode is variable...  a vortex WILL form, i've done this in a pool with a large circular set of pvc pipes with holes cut evenly in the bottom. ..i was not electrolyzing the water, just using an air compressor. ... it was an interesting swim.
Judges
Hero Member
  Re: am i missing something obvious?
« Reply #10 on: November 04, 2009, 08:08:11 PM »Quote 1) use energy to create a water vortex in the tank
Thank you.
Interesting,,,,,would notice first the funcunctionality of (3) above,or put otherwise,,am I missing something,,hmmmmmmmm,,,has anyone done the eloctrollyis thing?,,As a driller of oil wells (central texas),,, I am imediatly drawn to how much PSI over time,,,PVC should work,,,love to see a WORKING plan,,interesting indeed!
Good Morning America
Joe in Texas
wings
Quote from: jadaro2600 on November 05, 2009, 10:53:11 PM
see the effect Head-on Collision of Two Vortex Rings:
http://serve.me.nus.edu.sg/limtt/#Video_Gallery
same as pulsing mobious coil on TPU
